Question about Water Sport
Yamaha fx sho keeps coming up with fault code 142 an the oil is full what could it be?
2 Suggested Answers
SOURCE: left running for approx ten
First thing first... when it beeps... in the panel which little "icon" is blinking? Depending on which one, refer to your manual. I had this problem, and it was referring to low oil pressure which simply meant I needed to add about a quart of oil. Afterwards, worked great.
Posted on Oct 01, 2010
Fault codes for a yamaha nytro
Hi Terry, which year is your Yamaha Nytro and is it a XTX or other ?
Does it start while your codes are displayed ?
Follow the link below and you will find the error code definitions.
http://192.168.1.5/downloads/snowmobiles/Yamaha-Nytro/Nytro-Fault-codes-table/TY%204%20Stroke%20-%20Totallyamaha_%20View%20topic%20-%20Nytro%20Fault%20Codes,%20Relay%20Location,%20Fuse%20Location%20Diagrams.pdf
Mar 09, 2014 | Yamaha 2009 FX Nytro XTX
Yamaha wave runner check engine light comes one and will not run properly.
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Jun 09, 2013 | Yamaha 2009 WaveRunner FX SHO
Got my 2009 Yamaha FX sho waverunner under water, drained the water from the hull and tried to start it. Turned over 5 or 6 times and stopped. Pulled the air filter out and of course had water in it....
remove all sparkplugs and hold full throttle and crank over several times to get water out of cylinders ! have a jump pack ready as battery will die ! use carb cleaner on the plugs each time you try to run after this , hope this has only just happened as internal damage might already started ! if all ok check the engine oil also as water normally gets in after this problem ! if oil is milky then change oil several times , run for 15min on hose each change until oil normal colour ! then you must take for a run for an hour to help dry it out !
Mar 19, 2013 | Yamaha 2009 WaveRunner FX Cruiser SHO
FX SHO YAMAHA 2012. few hours, stops some times, at idle not always
Im not very agree either but i would tell them you have a lemon and want a replacement before they say too much time has passed.
Aug 14, 2017 | Boating
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
Left running for approx ten mins.warning light is on and beeping. i have a yamaha fx sho
If it will do at about the ten minute mark every time it is started up from being dead cold then the thermostat is probably stuck closed which will set off the temperature alarm.
Aug 21, 2010 | Yamaha 12V Air Pump
Hi I have a 2009 Yamaha SHO i were just wondering why can you still hear some parts of the motor spinning after you have shut down the motor..
It is the supercharger slowing down from its high spinning cycle. Dont worry about it, because it is normal. Trust me, I asked the same question on my 2008 SHO. You have the same motor I do.
Dec 23, 2008 | Yamaha 12V Air Pump
Water Sport Logo
214 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
