Question about Panasonic VDR-M95 DVD Camcorder
Can you re-record over top of something you've previously recorded
Hey just a standard question. I have some footage that I don't care to have/keep but I can't figure out how to re-record over previously record material. Please help! thanx
    Scholar:
  • 125 Answers
You can just record over it, no need to erase. Just make sure that the record protect tab is not in protect mode.
Posted on May 30, 2007
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
Hi, i would like to know if recordings can be downloaded from the Coby CXR190-1G to the computer.
Yes, absolutely!
I'm guessing you don't have the CX-R190 software that's compatible with your OS version.
No problem.
I use a patch cable between the AUDIO IN on my PC and the EAR on the recorder.
Since the ouput of the recorder is monoaural, all you need is a mono (2 wire) lenght of cable with a standard 3.5mm plug at each end. I made one myself, but I guess Radio Shack may have something like this:
If they don't have it, then a STEREO cable (3 wires) will work just fine.
Like this one:
To record the sound you can use any audio recorder.
I use Audacity. It's a freebie and pretty straightforward to use.
After you've plugged it all in, all you need to do is start Audacity and then start to playback the files from your recorder.
When they are on your computer, you can copy, cut, paste, add special effects, and later convert them to MP3 or whatever.
Good luck.
Jun 28, 2011 | Coby CX-R190 Digital Voice Recorder
I've recently purchased an FX38 to replace my previous Lumix (FX 28 I think). On the previous model I regularly used the audio dub function to record information about pictures, but can't find this...
hey sue
my best guess would be to play around with the menu's and/or look for a 'record' button, much like a button used to take pictures or capture video footage.
May 02, 2011 | Cameras
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Functionality in Europe
Hey taliadoros,
According to the manufacturer, this particular model appears to allow filming in NTSC format only. Unfortunately this means that in order to play any video footage recorded on this camcorder, the device being used to play the footage back would also need to be NTSC-compliant.
Please keep in mind that while some electronics sold in Europe may be both NTSC and PAL-compliant, it cannot be guaranteed that footage filmed using your camcorder will be compatible with all multi-format model devices.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 01, 2008 | Televison & Video
Downloading from hdd to dvd+r ?
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
Jul 28, 2007 | Philips DVDR3455H/37B
Panasonic VDR-M95 DVD Camcorder Logo
53 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
