Question about Dishwashers
I need to remove water supply hose from lg D1454BF dishwasher
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
SOURCE: LG dishwasher
I bought a stainless steel Lg less than 15 months ago for 800.00and it stopped working. The manufacture said so sorry even though you didn't take delivery until the end of Jan. your warranty goes by purchase date. I would of been better of with a maytag.
Posted on Mar 25, 2008
  • 417 Answers
SOURCE: inlet hose leaking.
Best to fit a new hose, the connectors are factory assembled and i would not risk a leak by attempting a repair.
Posted on Oct 14, 2008
MNTECH
  • 1543 Answers
SOURCE: LG dishwasher drain hose
You will have to remove the dishwasher from the cabinet, lay it on it's side, and remove the bottom access cover to get to the end of the hose. (it's usually not as bad as it sounds)
Posted on Mar 18, 2009
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Posted on Apr 06, 2009
HOW TO CLEAR CODE E1 ON LG DISHWASHER ?
The 1E error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Jun 13, 2014 | LG LDF7561ST FulIntegrated Dishwasher with...
We heard a loud gushing sound and the dishwasher leaked all over the kitchen floor. Why?
The drain hose may have disconnected from the dishwasher or at the waste trap or the drain hose maybe broken.
If the drain hose is OK then the water supply hose may have disconnected from the tap or the water hose is broken and fresh water is leaking from this hose.
Jan 03, 2013 | LG LDF6810ST Stainless Steel Built-in...
The dishwasher begins to start, then it stops, beeps and flashes the letters "IE" on the screen. We have tried every setting and it does the same thing.
Hello
The "IE" error code indicates a problem with the water inlet. The water supply valves are not turned on fully or the inlet hoses are kinked, clogged or frozen. Remove kinks in the hoses and remove clogs with a straightened coat hanger. If this does not resolve the problem, contact a service technician.
Sep 07, 2011 | LG LDF6810ST Stainless Steel Built-in...
Lg dishwasher ld2120w is displaying an error code E1 what does this mean
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. I resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first. I think the origin of the problem might be too much food on the plates and too strong of a dishwasher gel detergent so the food is turned into gunk which coats the channels of the plastic assemblies.
Add a comment
Nov 06, 2010 | LG Dishwashers
My dishwasher is an LG LDS 5811WW it reports an IE reading after one minute. Any help?
check clogging of water inlet hose ( or hose twist or freezing)....check water supply
Oct 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Installation
Hi
Please follow LG instrcutions for installation of your dishwasher, check the Installation manual--
LG Dishwasher Installation Manual
· You should have at least four feet of wire free at the end of the line where the dishwasher will be installed.
· Prepare the water connections. Use a proper compression fitting water supply hose.
· Remove any protective shipping packaging or screws.
· Cover any exposed wires with electrical tape.
· Check the water supply and drain hose for any leaks.
Hope this helps...
Daniel
Aug 14, 2010 | LG 24" Built-In Dishwasher - Black
LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
May 26, 2010 | Dishwashers
Never installed a dishwasher. Want to give it a try. Ha a LG LDF6920ST.. Any advice?
For water supply, use a braided stainless steel flexible dishwasher supply hose with 3/8 compression ends on each side and a 3/8 male NPT x 3/8 compression elbow adapter. There is a tee with 3/8 female compression x 3/8 male compression x 3/8 male compression which can be used between the hot water shut off valve and the supply tube to the kitchen sink faucet to get your hot water with no significant plumbing work. Make sure the drain hose does not run straignt down back to the dishwasher. (put a loop up to make sure no dirty water tries to go back to the dishwasher.) If installing drain to a disposer drain port, make sure the knock out plug has been removed. It's also easiest if the floor under the dishwasher is at the same hight as the rest of the floor in the kitchen. Make sure wire nut connections are tight for electrical.
Dec 04, 2009 | LG LDF6920ST Stainless Steel 24 in....
Keeps alarmimg 1E on my Lg Dishwasher
Inlet water error 1E
Not reached to the normal water level in spite of 10 min. water supply
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 24, 2009 | LG Dishwashers
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
