Question about Water Sport
My Yamaha fx sho keeps going into limp mode after a ride it comes up with fault code 142 what would it be?
  • 580 Answers
SOURCE: BMW (e39 1999) eml and asc lights and in limp mode
Check the ABS brake sensors in your wheels, if they are not functioning properly. It will trigger the computer to engage the ASC auto stability control light as the asc uses the brakes to assist in control. I will also engage the EML engine management light to slow the rev point to limp mode
Posted on Aug 23, 2009
SOURCE: My Audi A3 2.0 tdi limp mode/turbo overboost
i also have done a diagnostic test and it states a turbo overboost condition and it drives fine locally but loses power on the motorway and struggles to reach 80mph? any suggestions please email me at shiz86@hotmail.co.uk
Posted on Sep 14, 2009
  • 750 Answers
SOURCE: Holden rodeo 99 3.2v6 4l30e code 82 and going into limp mode
the tcm may be faulty or has a loose ground, try swaping in another if you can get one borrowed or a cheap used one from a salvage unit
Posted on Oct 30, 2009
  • 246 Answers
SOURCE: fault codes p1211 and p0251 keeps putting my van
Fuel injection circut malfunction.
How many cylinders
Posted on Jan 03, 2010
  • 138 Answers
SOURCE: Audi A6 3.0 tdi Quattro 2005, glow plug light comes on, limp mode
16619 -Engine boost condition - Limit not reached. Check intake hoses/ connections for leaks. Check Turbo charger waste gate regulating valve/ waste gate working correctly. Must move freely when accelerating, won't achieve full boost if waste gate sticking open. Check Turbo impeller turning freely, oil feed pipe for turbo can get blocked causing impeller to seize. Engine compact, not easy to access these components.
Posted on Jun 06, 2010
Hi guys just want to know the process to rest limp mode for Holden Captiva 2007 petrol
Read out the codes, fix the faults , cancel the codes, test drive if any codes come back the fault is not fixed , it won't come out of limp mode till the faults are fixed.
May 02, 2017 | Holden Cars & Trucks
95 Nissan Maxima transmission code p 07340 p 11005 transmission is in limp mode have erased several times
what have you done to repair the fault that shows the codes?
from your statement you are removing the codes and resetting the ECM but the codes come back and the vehicle goes back into limp mode
one of the codes (p 0734 --0?) refers to gear 4--incorrect ratio===causes --wiring---TR sensor /switch ---shift solenoids---transmission mechanical fault
If that fault area is not fixed then the TCM doesn't know what gear to select so it goes to limp mode
Jan 04, 2016 | Nissan Cars & Trucks
My 97 stratus keeps jumping into limp mode, i repaced sullenoid pack and two sensors, still in limp mode...anyone know why> should i have the computer flashed?
you should be having the fault codes read to find the fault
Limp mode is energized when some major problem with the engine or transmission is found by the ECM and it shuts down to prevent real damage
fix the fault or it will cost you big money
Oct 19, 2015 | Cars & Trucks
Ranger 800 limp mode error code 652 ??
If there is a fault with the engine the computer will go into limp home mode . a code reader number will give you the fault, after the repair the computer will have to be reset .
Sep 21, 2014 | Cars & Trucks
Yamaha wave runner check engine light comes one and will not run properly.
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Jun 09, 2013 | Yamaha 2009 WaveRunner FX SHO
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
Hi I have a 2009 Yamaha SHO i were just wondering why can you still hear some parts of the motor spinning after you have shut down the motor..
It is the supercharger slowing down from its high spinning cycle. Dont worry about it, because it is normal. Trust me, I asked the same question on my 2008 SHO. You have the same motor I do.
Dec 23, 2008 | Yamaha 12V Air Pump
Water Sport Logo
156 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
