Question about Video Game Consoles & Games
How do I fix a HMI Lite Moby Fault?
We currently have the following issue with our Operation. Two faults occured all of sudden: 1. Op170 In Station RF ASM Error & 2. HMI Lite MOBY Fault. We try to reset the station in No Mode and the station resets and the same two messages appear.
  • 52 Answers
SOURCE: when I try to delete
There was a problem when it first came out (not reading the hardrive correctly). Download a small demo or trailor and then delete all, this should work
If however it does not, then you will have to re-format the hardrive.
It sucks to be sony!
Posted on Jul 18, 2008
PuerkoNess
  • 275 Answers
SOURCE: while Iam update my ps 3 suddenly the update process stop
Sounds like a network connection error.
Check your WiFi connection settings on your PS3 and make sure everyting is setup corectly and are runnung at 100% speed
Posted on Mar 09, 2009
SOURCE: When loading a game on my DS Lite i get a black screen with the following error message 'ds load rom error code 7' reset system
It's because of the game , try downloading games from www.dohgames.com , it doesn't do that error
Posted on Jul 07, 2009
darktowernz
  • 191 Answers
SOURCE: play station 3 wont load games keeps saying an
go to this link......http://boardsus.playstation.com/t5/PlayStation-3-General/Error-8001002B-Can-someone-help/m-p/35138424.
its a dirty/damage disc error.
Posted on Mar 06, 2010
  • 11 Answers
SOURCE: Dsi (1.4E) It display the
You have updated. then after tried to use an R4 card. There is developers at nintendo whose job is to "hit" R4 cards to prevent sharing. It happened to me. The card still is good not the ds. it will work in other ds's not yours
Posted on Sep 14, 2010
Screen dont lite up on g2 phone
If the fault occured all of a sudden or with a fall then it can be failure of the display unit. To reset the phone , remove battery and keep aside for few minutes and then reset. If the fault stays but the call come comes through and if calls can be made, the fault must be the display .
Jun 28, 2012 | HTC Magic G2 Cell Phone
Finding and replacing a faulty coil pack
a failing coil will show up at the higher end of the rpm range because the faster it has to make spark, the weaker the spark not the other way around
have the fault codes read and save money by not guessing
from your description it could be a fuel pressure / injector ptoblem
Mar 29, 2017 | Cars & Trucks
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
Have a shu 4322 dishwasher it fills with water and drains but the spray arms do not spray. have not tried anything yet.this dishwasher is not hooked up. it was given to me by a friend who replaced all his...
Welcome to FixYa.
There was indeed a recall involving the control replacement nearly two years ago now if I recall.
As for checking into the present issue ( it doesn`t sound like anything to do with the control based on your description ) it sounds like the pump impeller may have become stuck. Did the dishwasher sit idle or in storage unused for a period of time ?
I have a service bulletin I could send you via email regarding remedying that issue of stuck impeller if you contact me at macmarkus@live.ca
I`d suggest you run the dishwasher through a diagnostic, but either procedure will require hooking it up.
To do this test/diagnostic on the SHU4322 series machine, it is as follows...
To start test program, press and hold both REGULAR WASH and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ "20" = version 0 without jumper).
When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone).
Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start button is pressed.
To start testing, press both the REGULAR WASH and RINSE & HOLD buttons a second time.
When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ "6" = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
2 = Heating fault
4 = Filling fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
i.e.
If water level switch has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch has failed (opened), display will show "0", water won't heat (to 150?F) and water won't stop circulating. If NTC probe has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating.
What needs to be done to solve the problem will depend on the results/findings of the dianostic, so let me know what you find and we can go from there.
Either way keep me in the loop and I`ll assist you the best I can. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Plesae describe the error code E00020
E020 There is a fault associated with the drum/developer.
For the first 2 digits of detail code xx12 through xxD0,
xx=01: Y
xx=02: M
xx=03: C
xx=04: Bk
xx20
xx24
xx25
xx30
xx34
xx35
xx40
xx50
The fault can occur as when a new drum
unit has been fitted. It is detected in about
90 to 120 sec after idle rotation of the developing
assembly.
unit has been fitted. It is detected during
ATR control or in about 150 sec after idle
rotation of the developing assembly.
assembly.
unit has been fitted. It is detached during
assembly.
The fault occurs when an image is being
formed. It is detected when toner supply
operation is started.
There is a fault/open circuit in
the ATR sensor. The drum unit
is not fitted normally, or is
faulty.
the SALT sensor.
the SALT sensor.
The ITB has deteriorated.
the ATR sensor. The setting of
the ATR sensor computation
value is wrong. The drum unit is
not fitted properly, or is faulty.
The sample image fails to be
drawn in ATR control. There is
a fault/open circuit in the SALT
sensor. The drum unit is faulty.
the SALT sensor.
The ATR sensor communication
value is faulty. There is a fault/
open circuit in the ATR sensor.
The drum unit has been fitted
improperly. (The machine cannot
detect the drum unit). The
The developer concentration
computation value is faulty (set
when a new drum unit is fitted).
xx60
xx70
xx80
xx81
xxA0
xxB0
xxC0
xxD0
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
new drum unit is fitted; the
value is extremely small).
The actual value is considerably
high in relation to the ITB surface
reflectance when a new
drum unit is fitted. The SALT
sensor is faulty.
drum is fitted.
The measured value of the developer
concentration is considerably
low. The ATR sensor is
faulty. The SALT sensor is
faulty. The ITB is soiled.
The drum unit is approaching
the end of its life and is causing
the T/D ratio to drop. The ATR
sensor has an open circuit.
The supply of toner for the toner
container to the developing assembly
is faulty. The developing
assembly is supplied with toner
excessively. The ATR sensor has
an open circuit.
has failed. The toner
cartridge motor fails to rotate.
The toner container is empty.
The toner supply mouth of the
drum unit is damaged. The ATR
code xxEE,
xx=00: fault in access to drum
unit
xx=01: fault in access to toner
container
The fault occurs while ATR control is being
executed.
executed.
formed.
formed and, in addition, when the T/D ratio
drops while 20 prints are being made
continuously. It is detected when toner
supply operation is started.
Aug 04, 2010 | Canon imageRUNNER C3200 Copier
Play station 3 wont load games keeps saying an
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Trying to download mystery gift from the internet to nintendo DS lite, keep getting fault code 51099
Look up the fault code on www.support.nintendo.com then follow the instructions listed. Problem will usually be fixed. Hope I helped. :)
Jun 28, 2009 | Nintendo DS Lite
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
