Question about Stoves Heating & Cooling
I have a CFM Electric Fireplace Model HEF22. My heater/blower works but when I turn the flames on they do not flicker. I am trying to find out if I need the Flame Generator Assembly or the DC Motor? And where to buy these parts.I live in Pinellas County, Florida
5 Suggested Answers
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
SOURCE: where can I get parts and/or service for my
open the back of the firebox unit where the flame is. there should be a long rod with small strips of metal sticking out. looks kind of funny. turn the "fire" on then gently push on one of the metal "leaves" to rotate. It might just start rotating again. not sure why it stopped. it may have something to do with being in the cold. perhaps the grease freezes up.
Posted on Nov 09, 2010
  • 4736 Answers
SOURCE: the flame effect isn't working.
You can either purchase one from DimPlex or online from Granger Electric.
Posted on Feb 02, 2011
SOURCE: I have a Pyromaster electric fire place = model
here is a picture of it. It took me about 4 minutes to put the new one in.
http://www.ibuyfireplaceparts.com/monessen/10001978-motor-variable-speed-12v-dc.html
Posted on Apr 05, 2011
Our fireplace is 22 years old and we are not able to start the fireplace.
Is this a flame effect electric fireplace with a fan heater underneath it?
If it is, the bulb has gone. Remove the coal or logs and remove the cover. You will see the bulb.
Dec 29, 2015 | Heating & Cooling
My dimplex electric fireplace model HEF22 wouldn't turn on
take out fireplace flame, 4 screws, in the middle is a thin sq. black box 1.5 inchs sq. with an insulated screw driver pull it forward. you should here beep,
if u do- unplug-get a good tape,put tape to keep it forward, what happens is it pulled backwards and the two pins slipped out of the circuit board. dust while u arre in there. hope that works for u. mine is working.keep fingers ccrossed. HAPPY HOLIDAYS
Apr 10, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
I have a pyromaster hef 337b electric firelplace. The flames do not flicker at all. The motor works, we tested it. Any other suggestions? Where could we find new parts for it
If you're not getting any flame effect or only a portion of it. One or more of the 60 watt small base chandelier bulbs is burned out. Replacing one or more should solve your problem.
Apr 14, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flame doesn't flicker
The "flicker" function in my unit operates with a system of rotating, reflective fins. The tiny, AC synchronous motor driving the fins failed and I got one one-line for cheap. A fairly simple R&R.
Only downside is the motor does not always start in the proper direction, but a start/stop or two resolves the issue.
Apr 08, 2017 | Kitchen Appliances - Others
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
529 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
vance jones
ghold1
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
