Question about Electrical Supplies
Engine Diagram for Tecumseh 10HP,Generator, HM100 159402P (B), Engine Diagram
  • 22 Answers
SOURCE: need carburetor part # 1481K10 for Tecumseh cast-iron sleeve 10hp
you could try a briggs and strtton dealer as they took over generac but think with it being a tecunseh engine you will have a big problem as that side of the company went under a few years back,sorry cant be of more assistance
Posted on Mar 30, 2009
  • 151 Answers
SOURCE: Tecumseh model 100 engine 10hp on a coleman
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Posted on Dec 24, 2009
  • 574 Answers
SOURCE: i need to replace the engine in my coleman generator
measure it
Posted on Jan 11, 2010
  • 468 Answers
SOURCE: i need the setting for my coleman power generator 10hp tecumseh
If you have fire coming out of the carb, then your intake valve is stuck open. Take the head off, and as you turn the engine, tap on the valve with a plastic screwdriver handle to make it go in, then turn it more to push it back out. If you need to put a light coating of oil on it, so be it. Keep doing this until it's freed up, then put it back together.
Posted on Feb 01, 2010
  • 10 Answers
SOURCE: I need to seperate the 10hp Tecumseh engine from
The rotating part of the generator{ rotating fields] is attached to the engine via taper lock. The engine shaft is tapered . you need to remove all generator parts and pieces to expose the rotating fields. Remove the long bolt that goes thru the fields into the engine crank. next take a 3 pound rubber or dead blow hammer and strike the fields(on the metal part) be sure not to hit the winding. This sometimes has to be done several times from both sides with alot of force behind your swing. eventually the taper lock will release. have patient and swing hard.good luck
Posted on Aug 08, 2010
I need to seperate the 10hp Tecumseh engine from the Generator? Best Procedure?
Simply unbolt it...nothing sp[ecial there remove the bolts that hold the generator to the engine housing the remove the bolts the hold the gen to the frame (if any)...REMOVE GENERATOR
Feb 02, 2010 | Coleman Powermate Premium Plus 6250W...
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
Sep 27, 2009 | Coleman Electrical Supplies
I need the setting for my coleman power generator 10hp tecumseh
Jun 08, 2009 | Coleman Powermate Powermate 5000W...
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Need carburetor part # 1481K10 for Tecumseh cast-iron sleeve 10hp
Dec 21, 2008 | Electrical Supplies
Electrical Supplies Logo
128 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
