Question about Pioneer VSX-915-K 7.1 Channels Receiver
Blinking Standby Light on receiver, no power
After a thunderstorm, the receiver just quit working. It was plugged into a power strip. It blinks at the power light bbut no output. Is there a way to reset this model?? Thanks
  • 85 Answers
Unplug from power socket for few hours,most likely had a surge from storm and destroyed,either way will need to be serviced to evaluate damage if power trick does not work
Posted on Jan 08, 2009
What does the red blinking lights on the "standby"
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 18, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Standby light keeps blinking but no picture
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
My standby light is red and blinking 6 times then quits, then blinks 6 times again then quits every time i try to turn on my tv
Apr 06, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Kdl-52xbr4 5 blinking standby lights
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
The standby red flashing light blinking
Dec 10, 2010 | Sony KP-53S65 53" Rear Projection...
Standby light keeps blinking with no picture
Dec 05, 2010 | Sony BRAVIA KDL-46V3000 Television
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
Goes to standby with fast blinking red light after 5 seconds
From my experience you need to replace the Hi power module
Sep 11, 2009 | Denon AVR-1905 Receiver
TV Lamp light blinking
COULD BE FAN NOT WORKING. TAKE BACK OFF SEE IF TURNING, CLEAN THEM. GO TO SONY.COM,TROUBLSHOOTING, OR SHUT THE TIMER OFF.
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jul 10, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDP-65S550 red light keeps blinking
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Pioneer VSX-915-K 7.1 Channels Receiver Logo
255 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
