Question about HP Pavilion dv1000 Notebook
How to switch the video feed
Switch video feed
  • 520 Answers
I assume you mean switch moniter to external monitor or tv.
fn +f4 together press once ...pc and external monitor... press again ..external monitor only... press again back to pc monitor
Posted on Jan 06, 2009
Why does a Century Quick Fix wire feed welder when turned on will not feed wire however it clicks without cycling.
Try posting a video or something more for us. Have you looked inside to see if the motor is turning?
Sep 10, 2014 | Welding Tools
JVC kd-r332 settings keep resetting after unit is turned off
I had this exact same problem - in my case caused by the wire that should provide a continuous feed so the unit can keep its settings actually being from the ignition switch, and the continuous feed wire being connected to the terminal that should be from the ignition switch! I had a red wire (continuous feed) and a yellow wire (ignition activated feed) feeding to the back of the unit, and all I did was to switch these over - both wires had their own connectors let into the wires a few inches from the unit so that switch over job was easy. Works as it should now, although i have a grazed knuckle as the wires leading to the plug at the back were a bit too short! Chris
Jan 09, 2013 | JVC Kd-r332 Cd Mp3 Car Stereo, Dual Aux-in...
Brother CS6000i feed dogs issue :(.
sounds like something may have broke or come loose,, I'd take the machine to someone else to have it checked to see what the poping sound was
Mar 09, 2012 | Brother CS6000i Computerized Sewing...
My car cd does not remember my settings. i allways need to adjust his settings
There are 2 battery feeds to your radio ...The main one via the ignition switch and the permanent one which feeds the memory.
It looks as though the permanent battery is missing.
Check the connector , wiring or the fuse
Apr 22, 2010 | Sony Car Audio & Video
Re-wire stereo in rover 400 cant find power wire
The following should be right, unless your car has different wiring colours, there are a few variants...
Yellow and Red = Switched +'ve feed from the ignition
White and Blue = Permanent +'ve feed
Black = Earth (-'ve)
Red and Black = is for the illumination when sidelights are switched on
If the above doesn't work join the following MG-Rover forum: www.mg-rover.org And add me as the referer: HotTubRepairer
Regards,
Ian.
http://hottub.synthasite.com
Mar 28, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
The video feed isn't happening.
this is most likely a resolution thing, if you are switching tvs and one resolution is higher than the other, if this happens when you start the box up hold down the right trigger and the "Y" button, this will reset the resolution to the default settings
Feb 26, 2010 | Microsoft Xbox 360 Console
I am installing a new after market DVD player. The old device had only 2 wires connected to a plug. The new player has 3 wires. a. Ground b. Power (on and off when key is on) c. Yellow battery (this...
you will need to reset all info each time you power off the unit if you dont connect thas feed, and in some units will not work fully, your car should have a switched power feed from the ignition switch and an aux ( permenant feed ) if not that u can just run it from any permenant feed inc the battery
Dec 24, 2009 | Car Audio & Video
Radio and dvd player and brake lights have all
YOU SHOULD HAVE 2 POWER FEEDS TO BACK OF HEAD UNIT, ONE IS SWITCHED OFF IGN AND ONE CONSTENT, WITH THE GALAXY ITS WIRED LIKE A vw/seat SO IF YOU HAVE FITTED A NON FORD UNIT THEN YOU NEED TO SWITCH THE RED AND YELLOW FEED AT THE REAR OF THE HEAD UNT. CHECK YOU HAVE 2 FEEDS GOING TO THE REAR, IF ONLY GETTING 1 YOU MAY HAVE A FUSE GONE, CHECK BOX UNDER DASH AND THE OTHER ONE UNDER HOOD/BONNET
Dec 06, 2009 | Car Audio & Video
How do i store the radio stations on a sony cdx dab 6650 itune radio in hold the button mem is displayed radio plays alright switch of car and ilose the station when i swich back on thanks.
have you recently installed this unit...if so, it sounds like you have not connected the constant live feed wire......there are 2 live wires, one only activates when you switch on the ignition, this is called , a " switched live feed "...the other stays live when you swith off the ignition, this is the " constant feed live "...this feeds the memory while ignition is off.. check the connections, and i think you will find this is the problem....
Aug 13, 2009 | Car Audio & Video
Loosing all ive saved when i turn the engine off
Easy fix, There are two 12+ volt feeds that should be connected to your unit.
1. Constant feed = 12+ volts that supplies power to the units memory all the time.This wire can be connected from the original radio connector wiring so long as it supplies constant 12+ volts, or be pulled from the battery, with an in-line fuse.
2. Switched feed = 12+ volts that only supplies power when the ignition switch is turned on,This wire can also be connected from the original radio connector wiring so long as it is a switched feed, also with an in-line fuse.
During installation ether these wires were swapped or the constant feed (memory wire) was not connected.
Good luck...
Feb 24, 2009 | JVC KDAVX44 Car DVD Player
HP Pavilion dv1000 Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
