Question about 1 Series Washing Machines
3edd varient coding and 46d1 control Unit internal 4 error codes bmw535d e60 car keeps cutting out
SOURCE: E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Posted on Apr 18, 2008
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
  • 73 Answers
SOURCE: f 11 error code on whirlpool duet washer.
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
Posted on May 02, 2009
SOURCE: Electrolux EWF 1087 error code E60
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customer error codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Posted on Dec 05, 2009
SOURCE: Electrolux ewf1087 washing machine error code?
what is a (e40)
Posted on Jan 02, 2010
Supra washing machine E60 error
E60
Washing machine motor does not work - no drum action or rotation or not spinning
  • Check motor wiring
  • Check motor
  • Check electronic controller
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3337-zanussi-zwg-range-washing-machine-error-codes
May 03, 2016 | Supra Washing Machines
What does E60 mean on a frigidaire dyer
Hello friend, thank you for your post!
I see that your Frigidaire dryer is displaying an "E60" error code. I am showing that an "E60" error code is not a valid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help could you please reply to advise what code your dryer is displaying or that "E60" is still being displayed. I look forward to assisting you further. -Matt
Feb 10, 2015 | Frigidaire Dishwashers
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
My AEG Lavamat 66600 Washing Machine is showing E60 Message how can I remove it to get the machine working again. Thank you
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60.
Check the door switch,drain pump and inlet flow.
Jul 25, 2012 | AEG Washing Machines
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
May 08, 2011 | Dryers
Code E60 flashing on screen of electrolux ewf1087 after powere cut during cycle. can't reset can't open help please
Electrolux E60 - NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or blocked or scaled up screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Mar 13, 2011 | Electrolux Washing Machines
Hi I have a Brother HL-6050D/N Error E60
E60 says the fan is not working, I would try first to blow it out, and after that look for a replacement fan.
Nov 27, 2009 | Brother HL-6050DN Laser Printer
E60 keeps flashing and beep noise. Machine is mid cycle and has come to complete stop
Or
Nov 13, 2009 | Electrolux Washing Machines
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Zanussi washer drier 1480W door lock
Zanussi's always keep clicking before starting.I don't know what E60 is about,but I take it the machine is working?
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
565 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
