Question about Jenn-Air JCD2389G Side by Side Refrigerator
How can you tell what year jenn air model jcd2389ges was manufactured
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
SOURCE: JennAir #JCD2389GES not cooling refrig at all.
Well guess what. Jenn Air / Maytag now has this issue as a recall. So just call them and tell them the fridge is not cooling. They will schedule a recall service appointment. Do be sure they schedule it as a "recall" service appointment or you will be charged.
That sure beats pulling out the hair dryer every time it happens!
Service number is 1-800-462-9824
Good luck
Posted on Dec 02, 2008
  • 13 Answers
SOURCE: i have a jenn-air jcd2389ges that is not getting c...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
Posted on Jun 03, 2010
SOURCE: Jenn-Air fridge not cooling
Yes, the problem is most likely with the
"ADAPTIVE DEFROST ENCL.
61005988.
I just watched my repair guy fix our fridge with this same problem ($232.75 later). What is happening, is that the freezer coil no longer defrost itself. Cold air cannot then blow into the refrigerator side anymore. To fix, remove cover at the bottom of the freezer and manually defrost the coils with warm water ... use bath towels at bottom of freezer to soak up the water. Replace the cover and then go to the refrigerator side. Remove the plastic cover at the top of the compartment to access ("ADAPTIVE DEFROST ENCL. 61005988).. This is a small plastic box measuring 3 1/8" x 3 3/4".
Simply un-plug the wires, and plug- in the new unit, then re-assemble with just a few screws. The retail cost of the part is $92 from the appliance guy, but you can probably find it on the net far cheaper.It's a really easy job that can be done by anyone slightly handy ...and you will probably save yourself at least $100 in the process. The next time this happens, I know what to do. It shouldn't take more than 1/2 hour for the whole process. If you mess up (which I'm pretty sure you won't) you should save some dis-assembly labor for your technician and some $ in the process. It's really easy to fix!
Posted on Jun 28, 2010
How do I find a discontinued part for my Jenn-Air Refrigerator Model # JCD2389GES? I need a specific part # 61005056 (black Escutcheon)
if the line is discontinued, that means NO ONE makes it anymore, sorry but there is no way around this one-buy a new fridge.
Jan 05, 2015 | Jenn-Air Refrigerators
How do i replace the water filter
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2389GES/1266/0165000
Nov 13, 2014 | Jenn-Air Refrigerators
JENN AIR jcd2389ges' SIZE,WEITH?DEPTH?HIGH?
Here is the site for the specs of that machine.
Jenn Air JCD2389GES
May 15, 2014 | Refrigerators
Jcd2389ges where is timer located
http://www.partselect.com/PS2061226-Whirlpool-61005988-Adaptive-Defrost-Timer.htm?SourceCode=1&SearchTerm=JCD2389GES&ModelNum=JCD2389GES gives and idea as to where it is located...it's usually in the plastic housing that the light is sticking out of. hope that helps
Jun 09, 2012 | Jenn-Air Refrigerators
REFRIGERATOR REPAIR MANUAL NEEDED
this web sight (fix-ya ) does offer repair manuels I would try it . as for parts info and prices. it will not be in the service . you can also down load this from the web sight .( service maters) from whirlpool . that now has jen air.. hope this has helped you mm feed back pls ..
Jul 23, 2010 | Jenn-Air JCD2389G Side by Side...
I have a jenn-air jcd2389ges that is not getting cold.it runs and works but is not getting cold ..
May 20, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389ges door not closing. My 5 year
it may be no hlp at all
but ive seen this a few times your problem sounds similar
check the soda milk door sometimes that gets jamed and will prevent the door from closing
Oct 08, 2009 | Jenn-Air JCD2389G Side by Side...
Grinding noise on right side of refrig ceiling
sounds like a relay in oyour adc(adaptive defrost control) is getting stuck causing the "chattering noise" you can replace the control easily for about $50.. the top cover pulld straight out and a few screrws hold the top panel up, to reveal the control box in upper right corner. turn off power before attempting lotsa wiresup there
Mar 02, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
115 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
