Canon photocopeyar ir 405 ip pcb error 240 so reples part
5 Suggested Answers
spinal
  • 287 Answers
SOURCE: Canon iR C3220 Printer TCP/IP settings
Wow,
I am not sure why or how I just bumped into this question 8 months later....and why no one has answered your question prior. I hope to God some one has helped you or you bumped into it on your own. If not, press additional functions,system settings, network settings, and the rest is obvious.
Posted on Jul 15, 2008
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
SOURCE: Canon IR 300-405 Problem -
dear sir i have canon IR300-405 machin.
my problem is error 030 pls full support is my solution
Posted on Jan 18, 2011
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
405 canon code e604 error ir machine xerox
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity
May 21, 2013 | Canon imageRUNNER 400S Copier
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
I am faceing the problem in cannon IR 405 M/C error code E-014 the fixing motor is OK Tasted on other m/c but same error code showing
it means the motor is receiving the OVER current meaning yoou need to solve the root cause of the problem. so change the power supply for the motor (PCB).
Jul 17, 2011 | Canon imageRUNNER 400S Copier
How to fix canon ir 405 error cod E805?
it is related to FAN, check all the connection of fan.
Apr 28, 2011 | Canon imageRUNNER 400S Copier
Hi canon IR 1510 error E 355 what is it? Please help me
Hi
On general canon machines error code of E355 indicates, 'When turning on the power, inconsistency among the serial No. PCB, the controller PCB (SRAM), and the counter memory PCB is detected.'
If this helps?
Jan 19, 2011 | Canon iR 2016i Black and White Copier
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
Jan 06, 2011 | Canon imageRUNNER 400S Copier
I need canon gp 405 Service manual that contain circut diagram as follows :- 1) IP Board ( Image processor PCB) . 2) DC - Controller . 3) CCD/PCB 4) Composite Power Supply . 5) Main Motor PCB . 6) Fixing...
this site have service manual which contain most of requested bits, including how to and what to do. it is not for faintharted do... :-)
http://www.scribd.com/doc/16699855/Canon-GP405-service-handy
if you find my answer helpful, please rate it, thanx!
Jul 31, 2010 | Canon Office Equipment & Supplies
Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Jul 25, 2010 | Canon iRC3100 Printer
E677 Error in canon IR400
switch main power off and on E677
Feb 24, 2009 | Canon imageRUNNER 400S Copier
23 people viewed this question
jasbo
jasbo
