Panasonic DMR-EX83EB-K 250 DVD playback problem
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
hawk12online
  • 16 Answers
SOURCE: NEED UNLOCK CODE FOR PANASONIC DVD RECORDER DMR-ES36V
I beleive FixYa Terms of Service state that you cannot give out Unlock codes for any type of device, hardware or software.
Posted on Dec 30, 2008
SOURCE: Panasonic DMR-BW500
I had the same problem. An authorised Panasonic service centre unlocked it under warranty.
Posted on Jan 29, 2009
Bati99
  • 88 Answers
SOURCE: panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Posted on Apr 19, 2009
SOURCE: Panasonic DMR-ES10 DVD Recorder unlock region
lock
Posted on Feb 27, 2010
When we put an SD card in, onTV we get 3" grey
This is a tv setting problem, not a camera problem. If you have a widescreen tv, it can be set to several width aspects. Check your tv manual for instructions.
Sep 27, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
Have a Panasonic DMR that will not work, keeps showing U61 code
u 61 means-displays when a malfunction has occurred,playback or copy.this is displayed when the unit is in the recovery process to return to normal operation,it is not broken.once the display disappears you can use the unit again.
Apr 26, 2010 | Panasonic DMR-E55 DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    Setting up the Panasonic DMR-E55 DVD Recorder
    If the freeview box has a SCART output, connect that to either AV1 or AV2 on the Panasonic. To record, select either AV1 or AV2 as the input. Use the other AV to connect to the TV to playback.
    Jan 28, 2009 | Panasonic DMR-E55 DVD Recorder
    No Sound when recording with DMR E100H Panasonic
    You should check that the connections and audio settings of your unit are as you require for playback.
    Nov 01, 2008 | Panasonic DMR-ES10 DVD Recorder
    Televison & Video Logo
    35 people viewed this question
    Top Televison & Video Experts
