Question about Refrigerators
I have a Kitchenaid Superba KSRS525 CKBT01 refridgerator and it keeps freezing everything and seems to never shut off
docjohn174
  • 943 Answers
SOURCE: KitchenAid Superba 48 Refrig
hi, is the fridge cold enough.pull fridge from wall, remove back panel. clean all coils. this should solve the problem. thanks the appliance doc
Posted on Oct 05, 2008
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
  • 9 Answers
SOURCE: My mother has a Kitchenaid Superba Dryer, gas,
WELL ITS 1 OF A COUPLE OF THINGS NO HEAT KITCHEN AID USES A THERMAL FUSE IN THE BACK OF THE DRYER CHECK THAT FIRST USE A MULTI METER FOR THAT ALWAYS UNPLUG ANY APPLIANCE WHEN DOING ANY WORK ON THEM IF YOU HAVE A GLOW DOWN ON BOTTOM IT COULD BE THE FLAME SENSOR IS BAD OR GAS VALVE COILS ARE NOT LETTING THE GAS OUT OR YOUR GAS IS OFF AT MAIN FROM HOUSE GOOD LUCK GEORGE
Posted on Apr 11, 2009
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
Oct 16, 2013 | KitchenAid Superba Architect KSCS25INSS...
The refridgerator portion gets too cold and freezes our food
If the two slide controls work and you can restrict airflow that would help. Usually a thermostat that does not respond to changes in temperatures are the cause. But we still need see if cahnces can be done to the airflow control. BRB with part numbers, Sea Breeze
Dec 19, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side too cold. Freezes everything.
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Water is pouring out of the top of the ice maker
you have to replace the ice maker .the water is metered via a timer built in it, the unit is not wrth servicing. they cost around 50$ you can do it yourself, they come with instructions. Good luck.
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
Drip/moisture tray inside base of kitchenaid superba refridgerator
need mor info,is there water in the bottom of your frig. or freezer,let me know more-mike
Oct 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water Dispenser Shooting Out Water (KitchenAid Superba)
check where water inlet is and water inlet is connected direct to the inlet valve - normally a double valve ie one water inlet and two water outputs. just disconnect wires from valve, making a note of where they go and tape them up
Sep 04, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Freezer not freezing completley
sounds like you might have a sealed system issue(ie.compressor, sealed system. check your user guide for warr inf you might stil be covered by manufacture for this issue
Jan 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
