Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak 5300 paper jam
I have a Kodak 5300 and have had a problem with the paper jamming for the past week.  I have tried all of Kodak troubleshooting and chatted with them online and called their 800 # and nothing is working.  I need help in fixing this paper jamming problem.
Thanks
    Problem Solver:
  • 5 Answers
What kind of paper is jamming?
The paper could be too thin, or too thick.
Have any young children visited you recently?
My neighbour's grandson thought the paper tray was a great place to hide his Oreo cookie and gummy bears. The crumbs on the roller made the paper wrap around inside. It was cheaper to buy a new printer than pay for a tear down. This happened to my neighbour over Christmas.
Check for spilled ink inside the cartridge area.
If Ink has dripped down on the rollers, that would jam the paper. This would only be an issue if anyone moved the printer. Could your cleaning person have done this? It happend to me, once.
Have you checked the slider that adjusts for different paper sizes?
It could be putting too much tension on the paper and throwing off the timing of the paper travelling through the printer, so the sheet is in the wrong place at the wrong time and jams up.
Is it 8.5" x 11" photo grade inkjet paper or 4" x 6" photo paper?
Before I print, I check that the paper type setting matches what is in the tray. If it is letter size premium photo paper, then I choose that paper in the printer settings. If it is premium letter size paper for documents then I choose that paper, so the printer can adjust itself to the paper.
Are you using recycled paper?
My Kodak, HP, Epson, and Canon printers jam. Recycled paper really screws up my machines. I don't like it and can't use it.
Do you have too much paper in the tray?
Try 5 or 10 sheets only in the tray to see if the amount of paper was the culprit.
Have you tried a different package or brand of paper?
One time a package of 500 sheets of HP inkjet wouldn't go through my KODAK , but worked fine in
the other printers. The next package of HP paper worked fine.
How long has the paper been out of the package and sitting in the printer?
Try fanning the paper.
Has the humidity in your area drastically changed in the past week?
I have to keep the paper sealed in the original package. Inkjet paper out of the package is affected by humidity where I live. Winter heating causes out of package paper to collect static and stick to the rollers. Summer temperatures with high humidity causes out of package inkjet paper to absorb moisture from the room. This humid paper sticks together.
Is the paper meant for a photo copier or laser printer/copier?
I get lousy results with non-inkjet paper in every brand of injet printer I use.
Is it Brand name InkJet paper, like Kodak, XEROX, or HP?
I stick to brand name inkjet and photo paper. Dollar store paper always jams in my printers.
For Document Printing I use either:
Kodak's 24 lb Ultimate Inket Printer Brightness 98 paper,
XEROX Premium Inkjet Brightness 98 24 lb,
or
HP 96 Brightness Premium Inkjet Printer 24 lb paper.
For Photo Printing I use Kodak's Ultra Premium Photo Paper, and adjust the printer's settings for it.
Posted on Jan 17, 2009
Kodak 5300 AIO Paper Jam
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper jams
Upgrade the Firmware of your printer at this link:
www.kodak.com/go/5500downloads
Thanks
Aug 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 AiO Printer will not work due to paper jam
Looks like the sensor for paper jam is causing you problems.
Worst thing is that Kodak discontinued the whole 5xxx series because of all the problems those printers had.
I don't know if you will be able to fix the problem through Kodak support, I guess you will have to give them a call.
Good luck,
Milan
May 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer says paper jam then please wait. Then it will not do anyt
well! the machine says that there is some paper in the machine, start by taking different itrems out such as the paper tray, look in the doc feeder and so on, good kuck
Feb 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to clean photo jam at my kodak all in one printer 5300 aio ?
if there is a paper jam then open the rear access door and look for any paper or piece of paper stuck in there if not then try and roll the roller slowly to check for paper jam........if you still cannot find the paper then open the front access door as if you are trying to replace the ink cartridges and look inside if you can see any paper stuck in there or not........if still no paper restart the printer after 30 seconds and check if still getting paper jam or not............if yes then contact Kodak tech support.......
Jan 30, 2009 | Kodak EasyShare Thermal Photo Printer
Paper Jam
on the back release the cover and pull it out. you cant release the tension.
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Paper jam
Paper jam out of the box is a doozy. Open the printer access door. If the printhead centers, remove the ink and the printhead. With the printhead out, unplug the printer and plug it back in. Replace the printhead once the printer is up and running. Close the access panel and the issue should be fixed. If the printhead does not center, unplug the printer with the access panel up, plug the printer in and turn it on (all with the access panel up). The printhead should center.
Apr 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer jam...i took the back off i see no paper jamed anywhere. I removed the paper and reinstalled it still the light come on saying there is a printer jam
To resolve this issue please do the following:
1. Open the printer access door(the gray part)
2. remove the cartridges
3. remove the printhead, to remove it press the release latch located on the upper left edge of the printhead where you put the black ink
4. Then close the printer access door WITHOUT the printhead and the cartridges.
5. unplug the printer and wait for 30 seconds and plug it back
6. it will give you a missing printhead error
7. install the printhead first, close it and then it should give an error missing cartridges. install the cartridges and if you no longer have the error upgrade the firmware by going to www.kodak.com/go/downloads
I hope that helps. If not contact kodak technical support for further troubleshooting.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paperjam then no power
unplug it..both cables..wait around 1 min..try it again. got backup?
Feb 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
529 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
