Question about Canon PC1061 Copier
Replacing inkcartrige directions needed
Having difficulty opening copier, to put cartridge in. Can you help Please
    Novelist:
  • 148 Answers
The copier opens one of two ways
try to open the door by standing in front of the copier and taking both hands see if you can pull open a door 1 /3 down from the control panel
if it opens see if you can see anything that is green in color these areas are wher you add toner
if you cannot get front door open see if it opens **** shell
one other otion is to look at right hand side to see if any panels open
Good luck
Posted on Jan 05, 2009
I am having a hp deskjet printer model d 1668 and the ink in the cartridge was exhausted before one month and i removed the cartridge./ now i bought a new cartridge but the systems shows there is a error...
A cleaning will fix the problem. To clean your Canon HP D1668 > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
Hope this help, thanks!
Oct 08, 2011 | Office Equipment & Supplies
Am having difficulty removing Black (96) print cartridge from an HP 7210 All-in-one printer/scanner to enable installation of a new (96) cartridge and need help!
on the software on your PC there was a option in the printer setting>> preferencess>> maintenance, which you can select the ink/cartridge replacement..
Jun 25, 2008 | Office Equipment & Supplies
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
LC 61 printout problems
As the manufacturer always suggest don't replace your ink with just a refill.
Please replace your ink cartridge with original ink cartridge.
Sep 19, 2009 | Office Equipment & Supplies
I am trying to take out the color cartridge and I can't get it out. Also I need to know how to put the new cartridges back in. Please help. G.J.
printer should be turned on...open the cover..cartridge will come in the middle and press the cartridge down and take it out...and put the new one in upward direction and you will hear a clicking sound.
Nov 26, 2008 | HP Officejet 5610 All-In-One InkJet...
How to replace a new cartridge
Here is a manula for your printer. Please check pg 59 for details how to replace cartridges:
http://h10032.www1.hp.com/ctg/Manual/bpd08798.pdf
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 02, 2008 | HP DeskJet 940c InkJet Printer
My printer is F380 and I am having difficulty replacing black cartridge. Do not have disc to refer to and no instructions in booklet. Can you please help?
just open the front door while the printer is on. the carriage will move and stand to the cartridge install position.hold the black cartridge pust it little bit towards down till it leaves the lock and then get it ouside towards ur side.fit the new cartridge in the reverse procedure.
thanks.
Sep 15, 2008 | HP Office Equipment & Supplies
Installing an ink cartridge
I struggled with this for ages! I thought there is no way this cartridge will slot into this printer!!
you have to switch on the printer first and wait for the slots to allign, then the cartridge will slide back and you click it up into place.
look on youtube, there are some videos of how to do it, really helped seeing it.
it is possible! don't give up!
Aug 11, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Need help with removing old cartridge so I can replace with new one on my Samsung 2010 printer
Here is a link that tells you how to install your new cartridge. Removal should be the oppisite of the installation.
Hope this helps.
http://downloadcenter.samsung.com/content/EM/200504/20050426164444203/EN/main.html
Jan 19, 2008 | Samsung ML 2010 Laser Printer
Canon PC1061 Copier Logo
50 people viewed this question
old marine
old marine
