MY PROBLEM IS I'M NOT VERY SMART, THAT BEING OUT OF THE WAY, HERE WE GO. WHAT DO I HOOK UP POINT A TO POINT B TO GET A KRA 5070 TO DRIVE A AMP?
  • 32 Answers
For this receiver you can connect an external amplifier but the signal to that amp will not be attenuated with the volume control on the receiver. Assuming that the external amplifier you are using has gain controls, you can use them for volume attenuation.
Connect a standard 2 channel audio RCA patch cable between the tape1 rec connectors on the Kenwood and the audio inputs on the external amp.
Good luck,
BB
Posted on Jan 06, 2009
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
Got a new battery in my kra and everything is working except the two time needles (hour and minute) is it broke?
If it was working OK before the battery was replaced, then it is unlikely that it should fail because you changed the battery.
Most electronic watches have an inscription "AC" on the chassis of the watch near the battery.
Instructions say that this point (or somewhere near it) should be connected to the case of the battery. Any metal implement will do e.g. a pair of tweezers would be ideal.
Althoughno maker seems to be willing to explain why you need to do this, I think that it resets the electronics.
Jun 18, 2011 | TechnoMarine Unisexs Kra Watch #KRA11
Cannot connect to internet how to subcribe my packet data
just call the servise provider or the network provider to activate gprs or edge. ask for settings and they will provide you. save the settings in your phone . activate the right settings and use it . hope your problem is solved. happy surfing.
Feb 02, 2011 | Nokia 5070 Cell Phone
CANON 5070 IMAGEWRITER POSTING "WASTE
To remove the recovery unit, open the upper right door & remove the developing unit. Be careful to unplug the toner sensor at the front frame. The plug will be damaged otherwise. From the front remove all the corona units. Slide out the fuser drawer. Remove the retainer screw & lock in the drum shaft. Slide out the imaging unit.
The recovery can now be removed.
Jan 20, 2011 | Canon imageRUNNER 5000 Copier
Unlock nokia 5070
You can unlock your nokia 5070 mobile using unlock instructions provided at http://www.unlocking4u.com/nokia-5070/rs6wp9/ ..
Nokia 5070 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 5070 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5070 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5070 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5070.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5070 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5070 mobile phones locked to the network Fido in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5070.
Jan 27, 2010 | Cell Phones
Timing on Singer 507 after replacing stripped drive cogs
Contact Singer by phone or by: Singer sewing machines.com thay should be able to assist.
Jan 05, 2009 | Singer 5070 Mechanical Sewing Machine
DVD DRIVE DRIVER FOR ACER ASPIRE 3623
Generally you don't need the Optical drive driver. Windows XP has built in drivers to support them. If you tell the exact problem then may be we can help
Nov 25, 2008 | Acer Aspire 3623WXMi Notebook
 Grubhead
Grubhead
