Question about Samsung SGH Televison & Video
On my top off my screen from my samsung wave gt-s3550 there's a blue E. It's for edge, i guess. But how do you get that of? Sometimes the blue E becomes a red E and at the end of the month I get a huge account :c help me please!
Lol .... XD
Posted on Mar 31, 2013
bestdarngood
  • 3037 Answers
SOURCE: Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Posted on Mar 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: 43FDX15B has blue lines on the screen somtimes
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white picture. Now adjust each CRT screen so that you end up with a true black & white picture. Then adjust each focus control to get a sharp picture, and adjust each CRT focus one at a time for clarity by covering the other two up. Then go back into picture adjust and turn color half way up, you should see a better picture.
If you cannot get the blue & green to even out to a black & white screen you have other problems such as faulty CRT card on back of tube or it could even be that the video IC is faulty. If this is the case, then you may have to get a competent local technician to check the TV and get the necessary parts replaced. It could set you back between $200-$400, depending upon how many components need replacing.
You can also try a hard reset..Unplug all cables, including power from the back of TV. Wait for 4 hrs and reconnect them. Try and see if it works now.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 26, 2008
Ecollier2012
  • 3459 Answers
SOURCE: i have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 29, 2009
  • 126 Answers
SOURCE: I have a Mitsubishi Rear Projection tv (vs-50705).
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Posted on Jun 06, 2009
Ecollier2012
  • 3459 Answers
SOURCE: hitachi 53fdx20b and it has a wave acrost the top
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 19, 2009
Unlocking code for diamond twister in samsung wave s525
Please help I want to play unlimited games 6 letters
Jul 30, 2012 | Samsung Wave 525 Cell Phone
I set phone password for my phone samsung wave GT - S8500 and I forget it. Please how can I solve the problem?
You'll need to reset your phone. To do this follow this directions:
Turn off Samsung Wave
Take out the battery and reinsert it
Turn it back on
Dial *2767*3855#
May 04, 2011 | Cell Phones
DOWNLOAD SKYPE FOR SAMSUNG WAVE GT-S8530
i download skype on my samsung wave
Feb 22, 2011 | Computers & Internet
Im looking 4 samsung mobile range of rs6000-8000 plz suggest mobile with 3.2 megapixel camera
1_samsung-wave-525_pbilimage1.jpg Samsung Wave 525 bottomarow.gifKey Factors Camera 3MP Bluetooth ver 3.0 with A2DP Music Player Yes FM Radio Stereo FM radio with RDS GPRS Class 10 EDGE Class 10 Talk Time up to 5 hours Video Yes Form Factor Touch Screen, Candy Bar Wi-Fi Yes Phone Book capacity Yes Memory up to 16GB bottomarow.gifPhone Features Size 109.5X55X11.9 mm Weight 100 gms Display Size 3.2 inch Display Colours 256K TFT, Touch Screen Call Records Yes Ringtones MP3 & MIDI Network Quad band Standby time Up to 150 Hours Battery Lithium, 1200 mAh Games 3D, Yes Java Tech MIDP 2.0 3G No SMS Yes MMS Yes E-mail Yes WAP Yes USB cable connection Yes, 2.0 micro Operating System BADA Head-set Yes Speaker Phone Yes GPS Yes, with A GPS Geo tagging Yes
Dec 31, 2010 | Samsung Star GT-S5233 Cell Phone
How to set up a Blueyonder.co.uk e-mail account on my new samsung wave phone
Step to setup an email account on Samsung wave:
1. Press Menu
2. Select My Accounts
3. Choose the type of email account you want to configure . For Gmail, select "Google "
4. Enter your e - mail address and password and click " Next "
5. A new window pops up. Select apply without making any changes.
You will need to configure your Gmail for IMAP or POP pushing first before authorization is given to your Wave to accept the pushed mail.
Login to Gmail -> Setting (top right hand corner) -> Forwarding and POP/IMAP -> Check Enable POP for all mail arriving from now on and check Enable IMAP.
You are done with configuring GMail side.
Now, add your google mail account under "My Account".
Enter your email (username will be filled up automatically), then your password.
Next, when you hit the next screen, DO NOT CONFIGURE ANYTHING. Simply "Set".
Make sure u have POP and SMTP enabled in your mail account before you try this and yahoo users make sure u enter your mail address as that of your domain
example : someone@yahoo..co.xx
where xx can be something like uk or us or in etc
Nov 01, 2010 | Samsung Cell Phones
How can i download skype on samsung wave 8500?
Go to the market place on your phone and search for skype.
Make sure you go to setting > applications > check unknown sources
hope that will help you..dont forget to rate me
Oct 20, 2010 | Samsung Wave S8500 Smartphone
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
