Question about RTO PasLode 900420 Impulse Framing Nailer
Paslode flashing red green light
Green light fashs normble till you go to fire a nail fan comes on runs shuts off . and when you pull triger the light starts flashing red green.
  • 131 Answers
SOURCE: paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Posted on Aug 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Posted on Sep 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: impulse gun wont fire and fan doesnt run
could be a bent probe not allowing full travel of the safety , fan motor, loose wire, or circuit assembly. If you are handy with tools, remove the battery and fuel cell. remove the 4 screws holding the cover on top of the cylinder assembly and down where the saety is remove the 2 screws there also. gently pull the cylinder off the tool. when you have apart check toe condition of the Oring on the top plate where the fan motor is. Now reinsert the battery and you will see a rocker switch towards the top, depress it and the fan motor should come on. if not try and depress the trigger switch and again the fan motor should come on. If neither start looking for loose or broken wires, if you find none then I would guess the terminal board would be bad. you can also remove the handle halves and look for a loose connection at the board itself, they sometimes wiggled loose where it plugs in. Good luck and let me know.
Posted on Apr 25, 2010
rowdy45176
  • 2176 Answers
SOURCE: battery flashes green until a nail is going to be
sounds like the battery is going bad
Posted on Sep 21, 2010
craig6773
  • 116 Answers
SOURCE: My paslode impulse framing nailer quit working.
It sounds like the contacts in the plunger are dirty or bad. Or even a wire for the contacts is loose. My guess is when you took it apart to clean it and replace the Orings you had moved the loose connection so it worked for a minute. On mine, I went all through the gun only to discover the wire feeding through the gas chamber was squished and broken inside. The wire's plastic insulation did not even have a hole in it. If you take it apart again check the wires carefully, check the contact points to make sure they are clean as well.
Another note, my father had issues with his and we went through it with a fine tooth comb. In the end we discovered it was a dirty contact in the gun where his battery hit. The battery itself was fine but once we cleaned the batteries terminals with a pencil eraser and plugged it into the gun we noticed one of the contacts had black stuff on it from the contact inside the gun. Works great every since.
Posted on Nov 24, 2010
My paslode nail gun is broken. I put the battery in and it will fire a few nails, but then the fan stops and the light will flash green then red. I have to reinsert the battery. Any ideas?
see if someplace around you sells dielectric grease. automotive store. what that does is: increase the electrical current between things, assuming that you have poor contact so few dabs of this stuff should be perfect it fills the gap between where the contact is lost and back in business.
Aug 22, 2015 | Air Tools & Compressors
Where is the spark plug on a Paslode 250ii finish nail gun?
GO TO TOOLS DIRECT.COM THE SPARKPLUG IS # 11 UNDER THE END CAP.BUT MAKE SURE YOUR SAVETY IS OK.THE SPARK UNIT ASSEMBLY IS #20 IN THE HANDLE.
Jan 30, 2013 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode 900420 fires only one nail and the battery has to be pulled and reinsert to fire again. After shooting one nail, the light alternate between green and Red. I have tried new fuel cell and fresh...
It needs to be cleaned and oiled. You can buy an electrical cleaner spray and oil specific for paslodes at Home Depot. You will have to take the back off (where the filter is) and clean it with the cleaning spray then oil it well. Put it back together and it will work like new again. You will be surprised how much difference it will make. Good luck
Sep 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350/90ct green light goes red when applied to surface and wont fire
Unplug. Check that you don't have a nail jammed in the end of it.
Apr 03, 2012 | RTO Air Tools & Compressors
Paslode 350 nailer wont work , push to fire fan works for 2 seconds then light flashes from green to red
Sounds like a battery contact problem or a bad battery..
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 17, 2011 | Dewalt D55141FNBN HeavyDuty 16Gauge Finish...
Paslode 16G finish nailer fires intermittently. Fan runs with each trigger pull but nail only fires about 1 out of 10 pulls if I'm lucky. I've installed a new gas canister so I know thats not the...
Clean it and oil it according to directions, then put a dab of dielectric grease on top of the spark plug. If this does not work ...Change the spark plug. I found one spark plug that had broken in half and made good contact intermittently which caused the problem you describe
Nov 27, 2010 | Craftsman Nailer Kit, Palm Air Driver
Paslode Impulse Framing Nailer won't operate
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
Paslode im250 f-16 only able to drive 2 nails .
Bad Fuel cell!!! New cyliders now have expire date on bottom of cannister. If old will not fire properly. Put new fuel cell in should be fine.
Feb 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
Nov 02, 2008 | Air Tools & Compressors
RTO PasLode 900420 Impulse Framing Nailer  Logo
396 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
