Error 3 on washer wm63141bk
Have smeg washing machine not working, showing error 3
SOURCE: Smeg Washing machine
This happened to us before and we had to actually reset the unit. I had to call the tech support and they walked me through the process.
Posted on May 29, 2007
SOURCE: washe machine problem
In other Daewoo models E9 error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes. It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor. It is often clogs with soap and other particles. Good Luck!
Posted on Sep 16, 2007
  • 52 Answers
SOURCE: Smeg washer/dryer not filling
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Posted on Mar 26, 2008
Jahn27
  • 1554 Answers
SOURCE: my smeg washing machine stopped half way threw
It is a code for draining problem. Pop the filter cap at the bottom front of the machine then drain the water through the emergency drain hose into a shallow pan or basin. If emergency drain hose is not present, place the pan or basin in such a way that it catches the water when the filter is removed. Remove the filter by turning it counterclockwise and clear it from any debris that might be blocking the water from draining out properly.
Once the filter is cleared, screw it back into place and plug the emergency drain hose then stuck it in and reinstall the filter cap.
Fill the machine with water then manually drain it by pulling the end of the drain hose and placing it into the basin. In this manner, you will now if the drain hose is clogged or not. Make sure the drain hose is not clogged or kinked and water flows properly down the drain hose.
You can tell that the drain pump is not working and needs to be replaced if the filter is clear, the drain hose is not clogged/kinked and water is flowing perfectly during the manual draining.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 24, 2010
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
Pe error on whirlpool washing machine
Check the motor brush they surely are dirt you can also clean the collector where the brushes lays on
Jan 28, 2014 | Smeg WDI12 Front Load Washer / Dryer
Washing machine is showing Error 14.
The only listing I have for Smeg states for 'E14' 'NTC dryer in short circuit or interrupted'.
'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man- it does say 'dryer' ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
Jul 27, 2011 | Smeg WD16BA Front Load Washer / Dryer
Hi my smeg washer drier shows e04 can you help me to find the problem.thank you.
The E4 error means Water temperature probe in short circuit or interrupted.Check the connection going to the water probe
Thank You
Sep 03, 2010 | Washing Machines
Smeg wm16aaa error code e06 Can anybody help me on the above please
HEre's a link to Smeg's web site with all the error codes:
http://www.smeg-service.co.uk/support/index.php?a=1#1
The only problem is that the code doesn't really tell you a lot though apart from it's probably not draining properly. Does any one have any ideas for E06?
G
Nov 08, 2008 | Smeg WM16AAA Front Load Washer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Mar 25, 2007 | Smeg WDI12 Front Load Washer / Dryer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
