Question about Creative Labs Zen Micro MP3 Player
Zen Malfunction My zen is all outta whack. first i was able to download songs no problem but it took forever and i was never able finish now if i plug it into any of the computers i have, all different models and stuff, it doesnt read it. also under the managment properties of the "MTA" or whatever device, it says, code 10 error or something i can still listen to the songs i have on it and radio and all that. just it wont let me addd any more. i've tried different chords different cp's uninstalling and reinstalling troubleshooting internet and it still wont recogniz it whats going on? help is much appreciated
    President:
  • 4,402 Answers
Can you try another computer or laptop, have you tried removing the software and reinstalling?
I know i have to use my laptop because my desktop does the same thing.
you can also try the recovery tool at creative
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Posted on Dec 03, 2007
SOURCE:
My mp3 player stays on all the time and i cant turn it off
  1. Check that the Creative Zen Touch has the most current version of the firmware driver. Firmware updates typically fix most common errors and problems encountered when using the Zen Touch. Turn on the MP3 player and select "System" in the home menu. Click "Information" then press "Settings." Select "About." Look for the internal firmware's version number listed under "Version." The most recent firmware is 2.01.00 and was released in 2006. If your software is outdated, download an update from the Creative support site: http://support.creative.com/downloads/download.aspx?nDownloadId=100120
  2. Ensure that the song files you are trying to transfer to the Zen Touch are compatible with the player. On your computer, right click the song file to view its file format. The Zen Touch can play all unprotected WMAs, WAVs and MP3s. It does not support the popular protected AAC format that is used in online stores such as Apple iTunes.
  3. Verify that the Zen Touch's internal battery is fully charged. This may cause what appears to be a blank or dead screen, as well as slow responsiveness to your touch. Insert the power adapter brick connector into the Zen Touch's power port found on its right-hand top corner. Plug the adapter into a wall outlet to begin charging. The MP3 player will be finished charging in four hours. You may use the MP3 player while it is charging, but this may slow down the charging process.
  4. Adjust the screen contrast on the Zen Touch. This may resolve any issues you have with viewing the screen in bad lighting. From the main menu, click "Settings" and choose "Contrast." Slide your finger up or down the Zen Touch's touch pad to adjust the contrast to a suitable setting.
Sep 24, 2009 | Creative Labs Zen Touch MP3 Player
Software gone and can't find songs on file in MP3
Support for Zen mozaic on this site:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
See the bar "All Downloads".
The "Application" should be reinstalled on your computer.
The software on the computer is required to get access
to your data on the player.
There is also a "Software AutoUpdate" available
on the bottom right side.
Aug 18, 2009 | Creative Labs Creative Technology Zen MP3...
Creative Labs Zen Digital Media Player
you should try to reload the songs
if that dosent work you hsould try to restart it.
if you unhoook the zen when you are loading the songs on that could be the problem too.
also when you are downloading songs you shouldnt be on powersaving mode and you shouldnt have any programs running,
Oct 05, 2008 | Creative Labs Zen Digital Media Player
Wont play all songs i have downloaded
Look under "all tracks". See if they're all listed there. Hope that helps.
Aug 08, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen mp3 player - computer won't recognise it
The ONLY AND I REPEAT ONLY way to solve zen and computer recognistion problem is to have THE ORIGINAL INSTALL DISK that came with player.
The only things that will work is
1. Download Utorrent 2. Go to google or yahoo and search Creative (you'r player type ie zen touch, zen mossiac, zen x, etc.etc.) install disk torrent. 3. Try to find the one that is closest to the name of your player (ie. zen touch, mossiac, x) and download the install disk. 4. After the download finishes you should be able to run setup like you have the disk.
I downloaded the install disk torrent and after i finished downloading I simply found the setup file clicked it and installed the neccessary files, and presto my computer recognised my zen touch.
#2 If you can't find a install disk for you perticular player, you should try to see if maybe a friend or someone youknow has a creative mp3 player and ask to borrow there install disk, who knows it just might work for you'r player. Best of luck and I hope this will solve you zen player/computer problem
Jul 17, 2008 | Creative Labs Zen Touch MP3 Player
Creative Zen 8g Hangs up and won't reset
I also had the same problem last week where my Zen was stuck on one song. I tried resetting it umpteen times, but it always went back to that song. I connected to the computer and went under
the Creative Zen application and had to format my whole Zen. I lost everything I had, but it was unstuck and I just downloaded everything again except that song. No trouble since then. Hope this helps.
Jun 27, 2008 | Creative Labs Zen Digital Media Player
Zen stone 1GB low battery even after charging
go and delete some songs by this your zen memory is free.
and go to adjust power property and select the right power management for ur eqipment.
Jun 22, 2008 | Creative Labs ZEN V Plus MP3 Player
Remove music
I had the same problem. You have to hold down the back button when you highlight the selected song. That back button is also the options button if you hold it down. You'll see a menu if you do it correctly. Then just scroll down to delete song and BAM...
it's gone.
Feb 09, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Labs 30GB Zen Vision:M
To put songs on your creative, just use the software that came on the cd. If you don
Jul 18, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen will not download anymore songs
The problem more than likely lies with windows media player. Update to the latest version.
Jun 29, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Micro MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
