Question about Dell OptiPlex GX520 PC Desktop
My acer aspire m1202 wont turn on
When i try to turn on it seams that it is only getting half power.the cd rom drive opens and closes and the blue lights are on but no video on monitor
novafire
  • 61 Answers
SOURCE: Dell 8100 Dimension will not find the Hard Drive or CD Rom
If the drives share the same IDE cable, try to replace the cable and make certain it is seated properly on the motherboard. Check for bent pins on either drive and on the motherboard IDE connector. Sometimes pins (especially near either end of the 2 rows of 20 pins) will bend under if they are not lined up with the IDE cable. Also check that nothing changed on the Jumper positions on the drives. They should be set to Master if both drives are single and Master (hard drive) and Slave (CDROM) if they share the same cable.
Posted on Jun 29, 2009
SOURCE: Dell Dimension 9100 Blue Screen
Hope this help you...This is in relation to what your error code means, you'll need to check against the list.
  • Error 0x00000024 - This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
  • Error 0x00000004 - occurs because your computer processor detected and reported an unrecoverable hardware error to Windows
  • Error 0x0000007b - occurs if your computer is infected with a boot-sector virus.
  • Error 0x80004005 - occurs because the account that is being used to access the page does not have access to the HKEY_LOCAL_MACHINE\SOFTWARE\ODBC registry key.
  • Error 0xc0000005 - occurs because of memory corruption.
  • Error 0xc0000034 - caused by a missing system file (usually Ntdll.dll in the %systemRoot%\system32 directory.
  • Error 0xc0000006 - occur if there is not enough free hard disk space on the NTFS-compressed hard disk partition when the SIS filter tries to read compressed back pointer data streams from the SIS volume.
Another common reason can be malware and spyware that penetrate to your computer registry and started destroying it... that's why it's so important you fix your registry right now!
trust this help.
Posted on Aug 17, 2009
rahulgaikwad
  • 137 Answers
SOURCE: Blue Screen Issues
Since you are using Dell Dimension 9100 ran a memory diagnostic for the blue screen. If you have 2 memory modules ,try reseating memory module and using 1 memory module to boot the system and then try to reinstall OS. If issue persist then replace memory with a different memory module, boot the system using dell resource cd or create bootable cd in DOS. DO a DEBUG follow the document from Dell support . http://support.dell.com/support/topics/topic.aspx/la/shared/support/dsn/en/alt_dsn_07302457082c47eda1a8f9619885f51f?c=us&l=en&s=gen
The using windows XP reinstallation cd try to reinstall OS.
Try the DEBUG as the last option.Good Luck.
Posted on Aug 19, 2009
rulds2008
  • 3866 Answers
SOURCE: Monitor does not light up
1. try the monitor on another system.
Did not work?
2. you need a replacement card inside the monitor this card is where the vga cable connects to the monitor.
or
3. you have a bad connection or solder joint inside the monitor.
4. if it does work on aother computer check your current computers video card.
Thanks I would love to hear your feeback on our service.
Posted on Sep 22, 2009
  • 11 Answers
SOURCE: cd rom door stuck closed. paper clip will not work
does it kindof move a little when you push the paper clip in then goes back in (only about a millimeter)
Posted on Dec 23, 2009
I have acer aspire 5315 and i cannot open the cd drive.
Hello.
If the drive does not open on its owm, you should be able to open it manually. The drive will have a smal hole in the fronto of it. If you take a straightned paper clip and insert into the hole the drive should open.
Feb 23, 2011 | Acer Aspire 5315-2153 Notebook
My cd drive wont open or read disks anymore what can i do to fix this?
If its not reading your CD any longer, you will need a new CD Rom drive. If it not opening either, the power to it needs replaced which is the whole unit.
Dec 31, 2010 | Acer Aspire 4520-5582 Notebook
No dvd/cd rom icon
From what I read, Acer Empowering software is no big deal. Some say it's fine, others say nothing worthwhile. If you aren't thrilled with it, you might consider uninstalling it and seeing if it brings your CD-rom back. If you want to keep it or uninstall of Empowering software doesn't work, uninstall the CD-rom and then let Windows rediscover and install it again.
Go into Device Manager, right click on CD-rom and choose uninstall. Close out and restart.
Sep 06, 2009 | Acer (91.47A37.001) CD-ROM Drive
Black screen.
A few questions up ahead please:
a. Is the power button lighting up when you press it or power on your laptop?
b. Is the battery fully charged?
c. is the power cable/charger still good when you connect to mains supply?
**If you answered YES to all the above...
Your laptop screen may be bad and as such must be replaced.
Otherwise, The windows operating system may have CRASHED.
If this is so, then you can try out this system recovery tips as the last resource:
1. try remove the hard drive which you can access by opening the back cover as shown in the owner's manual.
2. next, connect this through an external usb casing to another system and backup all files on the hard drive.
3. if you don't have an acer recovery cd(s) for your laptop, try get someone who has and can help you burn the software for your model and make.
4. next, format the hard drive before you reinstall it back into your laptop.
5. power on your laptop and continously press F8 to enter the bios setup.
6. Select bootup sequence and select boot from cd drive.
7. first reinstall a lower version windows os by inserting a bootable system software.
8. after installation, keep the cd rom drive open and shut down your laptop.
9. insert the acer system recovery cd into the cd rom drive and close shut.
10. Restart your laptop then, Follow the instructions and prompts.
Your laptop will be restored to the way it was originally from the manufacturer.
Jul 08, 2009 | Acer Aspire 5050-3242 Notebook
Cd/dvd-rom drive E: not detected
plz check in the bios the cd rom is enable, then check the datacables try with a new data cable
Jun 19, 2009 | Acer Aspire 5315-2153 Notebook
\Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Mar 22, 2009 | Acer Aspire One PC Notebook
ACER ASPIRE 5100 DVD/CD ROM IS NOT DETECTED IN BIOS?
do you get an error 200 yet ? i got one here that does the same thing and its a bad motherboard. tried to replace cd drive and harddrive and was no help
the motherboard cost to much and not worth the part and labor
Dec 04, 2008 | Computers & Internet
Cd/Dvd Drive
You need to read on the drive and see exactly what type of drive it is. A DVD-ROM drive is read only and will NOT burn DVD's. The drive needs to read DVD-RW, in order to burn DVD's.
Jun 20, 2008 | Acer Aspire 3000 Notebook
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 3610 Notebook
Dell OptiPlex GX520 PC Desktop Logo
Alun Cox
