Ricoh mpc5000 sc672 error - Office Equipment & Supplies
5 Suggested Answers
  • 15 Answers
SOURCE: sender not specified ricoh mpc5000
go into user tools file transfer settings then enter anadmin email address then theres a box that says auto specify sender name select that.
Posted on Apr 18, 2009
  • 903 Answers
SOURCE: check the meter on a Ricoh MPC5000
On an MP C5000, press the User Tools button on the operation panel, then on the touch screen press Counter.
You'll see the various totals for copying and printing, and it will be broken up for color and black & white. If you want to print out a sheet with all of the meters on it, just press Print Counter and then hit the green Start button.
Posted on Jul 06, 2010
  • 903 Answers
SOURCE: We've a Ricoh MP3500 that is displaying an error
sc672 is a communication error between the controller board and some other component. Did you switch the machine off using the orange power switch on the lower left side, or just the power button on the operation panel?
With the power completely off and the machine unplugged, pull the controller board out by removing the two screws holding it in on the rear left side of the machine. (It should slide right out the side.) Check all of the connections on the board and make sure everything is sitting securely, then reinstall the controller board.
Worst case scenario, you might have a bad memory stick, bad controller board, or another bad circuit board, but more than likely there is a connector somewhere that just needs to be set securely. You can also remove the operation panel (two screws on the top of the panel and possibly two screws underneath it as well) and check the harness that connects the op panel board to the machine.
Posted on Jul 17, 2010
Testimonial: "Thanks for the help...looks like we've got to replace the controller board :("
  • 352 Answers
SOURCE: I have windows32bit OS installed
Hello.
Not sure if it is possible. X64bit drivers are written for a processor capable of handling 64bit commands, trying to install them on a 32bit CPU simply wont work.
Sorry for the bad news Regards GM
Posted on Aug 01, 2011
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
Ricoh error code
take the HHD out and put it on a cradle attached to a pc. Format HDD and 9 out of 10 time it recovers. After reinstalling it in the mch format it again in Sp mode
Also check the fuser on the Lower controller PSU . ( sits at the bottom of the controller )
Nov 01, 2013 | Ricoh Computers & Internet
Brand Aficio 3030 and mpc5000 cannot get into service mode once error 672 is displayed. the only way was to replace the main controller if there any other ways to settle this error 672
I think that the problem is with the HDD. Did you try to remove the HDD? Try to un-plug it and turn machine ON. If it works you just need to format and recover the HDD. Or replace it with a new one
Nov 15, 2011 | Ricoh Office Equipment & Supplies
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Check the meter on a Ricoh MPC5000
Jul 06, 2010 | Ricoh Aficio AP3200 Laser Printer
Sender not specified ricoh mpc5000
Apr 02, 2009 | Ricoh Aficio AP3200 Laser Printer
Ricoh 1035
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Jul 31, 2008 | Ricoh Aficio 1035 Copier
317 people viewed this question
jasbo
jasbo
