Question about Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Model 7MMVWC310YW purchased in Mexico for our Mexican home. The washer does not have a water level select and obviously detects the amount of clothes and adjusts the water level. Is there any way to change or bypass? I feel that there is not enough water to adequately clean the clothes.
    Top Expert:
  • Maytag Master
  • 52,423 Answers
There may be a choice between manual and automatic level setting. Check the panel.
Posted on Jan 05, 2018
SOURCE:
  • 163 Answers
SOURCE: Washer spins but not enough to extract water from clothes or tub.
it sound to me to be the water pump, with all the water in the tub, the machine dont spin ok, and the water is extracted by centifugal force, not by pumping as it should be, call a tech, this is a hard job for regular people..good luck
Posted on Aug 10, 2006
SOURCE: Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Posted on Nov 19, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 19, 2008
farfield
  • 462 Answers
SOURCE: Maytag Washer PAVT-1 continues filling with water to overflowing
Does it still do this with power to the machine off? If so it is your water fill valve. Because no power is getting to the valve it has to shut off unless some foreign particles are holding it open. Remove and replace the water fill valve if still runs water after power is off.
Here are some things on how the selector switches work: If it stops when you remove power look at these possibilities.
Water fill switches usually have an air tube that as the water level comes up the air pressure increases and causes the switch to go from fill to wash.
I have seen rodents chew holes in the air tubing and this could be the cause or you may have a bad switch.
Some times the switches also get out of calibration and need readjusting (especially if you have moved in altitude like up a mountain or into a valley).
If this helps you please rate me as high as possible.
If it doesnt help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Posted on Mar 24, 2009
Washer_tech
  • 164 Answers
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Posted on Mar 31, 2009
What does F 20 mean and hoe do I fix it
For some Maytag front-load washers, the F20 error code means that no water was detected entering the machine or the water entered but didn't reach the fill level. There are several things that you can check that may solve the problem.
First, are the shut-off valves for the inlet hoses open? Next, do you have both the hot and cold water connected to the unit and open?
There are filters in the washer (before the fill valve) and in most hoses. Remove the hoses and check for clogs/debris. While you have the hoses off, check the flow rate of the water at the shut-off valves. Some anti-flood hoses will restrict the water flow if they detect damage. Replacing the hoses can solve the problem.
Next, make sure that the drain hose is not positioned below the washer fill level. This causes the water to be suctioned out of the washer as fast as it fills.
If these steps don't solve the problem. Then your issue is at the fill valve, the controller or the wiring harness. The valve isn't opening properly - either because the valve is bad or the message to open the valve isn't being received. Additional tests will be needed to determine the fault.
Please add a comment with the model of the washer for additional assistance. I hope this helps.
Feb 02, 2013 | Maytag Washing Machines
Top load Maytag washer about 20 years old. Fills OK with water but will not agitate. Cannot hear timer ticking at any time. Thanks.
You might have a sensor problem that prevents the cycle from proceeding.
Most washers have a sensor that detects the water level, thus allowing the selection of Small, Medium and Large loads and the related water level.
Some sensors also use a breather tube, which can become clogged with fluff or debris, causing the same symptom.
Only when the sensor activates, will power be applied to the timer or rotary control unit's little motor, thus causing the cyle to proceed.
Feb 12, 2011 | Maytag Washer Timer - 22004015
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
At the end of cycle washer will not stop filling and overflows. maytag neptune fav6800aww
There is a diaphram switch located in the machine at the bottom right in the rear. When you remove the front panel it will be all the way back on the right. It senses the water level. It has three levels it detects. I had a problem with mine filling too much. That should take care of your problem.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer codes says OE...never have seen this one before...
A fault is detected in the water level sensor. Data (frequency) shows the water level is at or above the overflow level.
Mar 21, 2010 | Maytag MAH8700A Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
Maytag washing machine model PAV3360AWW won't stop water on selected water level.
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
Dec 30, 2008 | Maytag PAV2300 Top Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
