Question about Fujitsu Heating & Cooling
Need to change the batteries for the remote control - can not find the way to open the battery compartment
Model AR-DL2
snowman767
SOURCE: Zenith Remote controller
Have a Zenith Remote 124-202-01 with MBR3440 on the inside cover of the remote. I've tried all kinds of numbers and generic numbers without any luck. Anyone know what the code is for my 1995 32" Zenith TV System 3 TV?
Zenith and LG TV support queue in Canada 18885422623 8-5 CST.
Zenith and LG TV support queue in U.S. 18779936484 24/7
Zenith 32” TV System 3 Model Number #SM2771S
Solution: Unplug the Zenith TV for approximately 5 seconds. Remove batteries in the Zenith remote. With the batteries removed press the TV button on factory remote and then the power button 5 times and hold the power button on the fifth time for approximately 10 seconds (I suspect this just clears the internal memory of the remote). Put the batteries back in the remote. Plug the TV back in and the remote should work again. My remote did work again successfully.
Posted on Jun 11, 2008
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
SOURCE: Zenith universal remote control
I have this same remote with the same markings in the battery compartment. This remte is the same as Phillips/Magnavox model PM725. You can download the PM725 manual here: http://www.remotecentral.com/index.html
Posted on Feb 27, 2009
  • 634 Answers
SOURCE: fujitsu air conditioning remote control not
open the remote and carefully look at where the batteries make contact they sometimes bend in and dont make contact just pry them out a little and reinsert batteries and it often will work again
Posted on Jul 07, 2009
SOURCE: HBW1241 Can Not Change Remote Battery
I have the same remote. You need to wedge in a flat-head screwdriver. Push it into the plastic and turn. This will release it from the catches. Now I just have to find out where to get the flat 1/2" lithium battery to replace it.
Posted on Aug 02, 2009
How do i sync a fujitsu ar-dl2 air conditioning remote with air conditioning unit
Here is a link to current units: http://www.fujitsugeneral.com/PDF_06/OperationManual/(OM)ASU24CL-30CLX-36CLX.pdf
there is no indication that synching is required for OEM remotes, just chack and make sure the batteries are good. If it is a universal type remote, the remote manufacturer provides those instructions.
Nov 26, 2014 | Fujitsu Heating & Cooling
How i restore default admin password on a Sharp MX-M452N
Download the manual here: http://dl2.opendrivers.com/dl_file.php?dl=dl2&brand=multifunction%2Fsharp-electronics&file=MXM282N-M362N-M452N-M502N_OM_Online-Manual_GB.pdf&check=a35c9re0e86ed5&driver=cs6f4548 dl2 opendrivers com
Nov 24, 2014 | Sharp Computers & Internet
Download fash layer
http://dl2.soft98.ir/soft/a/Adobe.Flash.Player.24.0.0.194.firefox.exe?
Nov 28, 2013 | Adobe Systems Adobe Flash Player
I have an split-type aircon (brand: Fukitsu) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift indoor unit cover and remove DC wire from display sensor. After 3 minutes again plug it and close the door. Now you try with your remote. If still problem, check your remote through cell phone camera by pressing any button in remote. If ultra light is visible thr' camera, remote is o.k. If remote is o.k, repair/replace PCB. Thanks.
Feb 09, 2011 | Heating & Cooling
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
WHAT CAUSES THE FREEZING OF THE PANEL WHISLT ENTRIN' SIMULATION
Ar-Al models are digital .ar-m some models with color scan.SF models are old and analog.
May 06, 2010 | Sharp AR-M205 Copier
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Jul 17, 2009 | Sharp Office Equipment & Supplies
Heating & Cooling Logo
66 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
