Question about Air Tools & Compressors
Air blows from side of air wratchet - Air Tools & Compressors
    New Friend:
  • 27 Answers
The air blowing out the side of the ratchet is the exhaust. All ratchets do this. The air going in from the compressor must exit somewhere.
Posted on Feb 18, 2013
Air conditioning system, when you turn on the air conditioner the drivers side blows cold air and the passengers side blows hot air? What causes this problem?
The most common cause of this is that you have a stuck air temperature control blend door, this can be a motor actuator issue or a jammed door or both (common). To replace both parts you will need to completely remove the dash from the car to access the blend door.
Jul 02, 2016 | 2010 Ford Flex Limited
Hot air from drivers side cool air from passenger side
Driver's side blows hot air; passenger side cold air - Hyundai ...
www.hyundai-forums.com/.../294097-drivers-side-blows-hot-air%3B-pa...
Jul 29, 2014 - 3 posts - ‎3 authors I soon noticed that the driver's side blows warm air and the passenger side blowscold air as it should. No amount of adjusting the temp control ...
Hot air on driver side vents - Cold on passenger side - Page 3 ...
www.odyclub.com/.../46646-hot-air-driver-side-vents-cold-passenger-si...
May 9, 2012 - 16 posts - ‎10 authors I have a 2009 EXL Odyssey that just is doing the same thing (warm air on drivers side, cold on passenger). I checked freon levels and ...
Oct 15, 2015 | 2009 Hyundai Sonata
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
The air conditioner starts blowing hot air on the driver side while the passenger side blows cold air.
2004 Suburban air conditioner blows hot air to the dirver side but cold air to the passenger. This does not happen all the time but has occurred several times this last summer.
Sep 14, 2010 | 2003 Chevrolet Suburban 1500
How much tork on oil pan bolts, 1989 precis rs
25 ft lbs or if u do not have a torque wrench when using a wratchet hold the end of the wratchet (gear end in the palm of your hands and tighten as tight as you can it is aprox 25 ft lbs when done make sure you use a patern to prevent torque twist of the pan
Dec 06, 2009 | 1989 Mitsubishi Precis
Need cylinder and cylinder head torque specifications 98 XR 250
you dont need torque specs on that just use a 1/2 inch drive with you 14mm or16mm socket hold the wratchet right at the top and tighten it as tight as you could get it like that then use wratchet in normal position and just give it a little snugg it will be perfect i have done it a million time on the same type of bikes...
Dec 05, 2008 | 1998 Honda XR 250 R
A/c and heater
Is it leaking antefreeze?
The thermostat might be gone or needs a bigger thermostat
It could be a vaccum leak for the drivers side blowing cool air and the passenger side blowing warm air
Does it have dual air control switches one for drivers side and one for passengers side?
Oct 28, 2008 | 2003 Pontiac Grand Prix
Air Tools & Compressors Logo
403 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
