Question about Nikon N65 35mm SLR Camera
N65 built-in flash not working
I just got my N65 back out to play with and the flash is not working. It will take pictures in all modes, but as soon as I try to take a picture with the flash up, it will not take. Is there any way to fix that?
  • 88 Answers
Yes, you can. Unfortunately Nikon is so backed up with repairs, your camera will probably take a few months to get it back and cost you more than you want to spend. The labor is what is so much. Just like fixing your car a shop. Your camera probably has a flash sensor that has worn out or needs to be re-callibrated is all. I have a friend who fixes cameras.
http://www.cameradr.com/
Check it out
Nate
Posted on Jan 08, 2009
I have a nikon n65 and there is a blinking F- - what does that mean?
The F-- indicates that the camera isn't communicating with the lens. If you have an old mechanical lens with no electronics, you'll have to set the camera to the Manual exposure mode (turn the mode dial to M) and shoot without any help from the camera's light meter.
If you're using a newer AF lens with electronics, clean the electrical contacts on the back of the lens and in the mount on the camera body.
Jul 13, 2012 | Nikon N65 35mm SLR Camera
N65 shutter button failure
Follow this link: Nikon N65 Camera Body 35mm SLR. You can buy a working replacement body for $19.99. A camera repair man will charge you three to five times the replacement cost.
Jul 04, 2012 | Nikon N65 35mm SLR Camera
I just put new batteries in my N65. I haven't used it in a while but it appeears to be working proper, ie the lcd comes on and indicates full battery and the view finder symbols are nice and bright green...
What I'm thinking is the shutter and or the aperture ring is lazy. Move the aperture ring up and down several time see if the little ring next to the the camera body is responding quickly to the change.
Do this without film in the camera.
What I'd suggest is setting the camera in "M" mode aperture at F8 manual set the ISO at 100 and the shutter speed at 1/60 shift the camera into manual focus. The shutter can be in AF-S (single frame with each depress of the shutter). Trip the shutter and listen to it work do that a few times (maybe three) then set the speed at 1/125 do the same test listen the shutter should sound faster. Repeat the test at 250 then 500 then 1000. Then start backing down to 1/60th again, listen to the response. In all manual mode the shutter has to fire it it isn't or the speed doesn't increase and then decrease then the shutter needs service.
Jan 14, 2011 | Nikon N65 35mm SLR Camera
How can i turn the flash off of my nikon n65 camera?
In the PSAM modes the flash won't pop up on its own. In the AUTO and vari-program modes, you can set the flash mode by turning the command dial while pressing the flash sync mode button (marked with a lightning bolt symbol). Select Flash Cancel (lightning bolt in a circle with a slash through it).
If you need a manual, you can download one at
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Dec 22, 2010 | Nikon N65 35mm SLR Camera
The batteries are dead on my N65, but when I pushed the button that pops the flash up, nothing happened. Wondering if that is because of the batteries or if the flash is stuck/broke?
Battery is needed to unlock the catch then the internal flash will pop up. These cameras are programed to automatically pop up in certain modes so there is a little electric switch used not battery no switch. Don't leave the dead battery in the camera or you'll end up with more problems then just replacing the batteries.
Dec 10, 2010 | Nikon N65 35mm SLR Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Nikon N65 won't take picture
The problem is, that you have a lens witch has an aparture ring on it and some exposure modes needs it to be fixed on the smallest aparture (e. f22). When its done the camera should not say fEE no longer.
May 15, 2009 | Nikon N65 35mm SLR Camera
My Nikon N65 flash leaves a dark spot on all my photos
tlguthrie,
I love that camera. There are several possiblities, If you are using the pop up built-in flash with a telephoto lens or a lens hood you'll get a shadow in your photos ususally at the bottom of landscape oriented shots. If you are using a flash unit attached it may have something interfering with the strobe possibly or it is turned. We have the same camera and have had the shadow issue in the past. The pop up just won't work if something is wrong with the "bulb" the only other thing is that is isn't going all the way up, check that also.
randy32osgi
Jan 13, 2009 | Nikon N65 35mm SLR Camera
Camera wont let me take any pictures it just says FEE?
That usually means that the lens you have mounted on the camera is not set to its smallest aperture (ie 22). It needs to be set that way so that the camera can control the full spectrum of aperture positions when shooting in one of the auto program modes.
Dec 28, 2008 | Nikon N65 35mm SLR Camera
vickiep24,
Since you didn't mention anything about shooting in manual settings I'm going to guess you have been and the camera work there in shutter or aperture mode, so make sure you set your lens's F-stop back to the auto position - check the dot on the lens ring with the f-stop numbers (usually in red) like the f-22 make sure they are aligned when in auto so when the camera needs more light and the lens can fully open to give it the light it is asking for, then it will shoot otherwise it won't. Does that make sense.
randy320sgi
Oct 17, 2008 | Nikon N65 35mm SLR Camera
Nikon N65 35mm SLR Camera Logo
54 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
