Question about Garden
I have rz2454 husqvarna the starter selenoid was bad i replace it and the mower was working fine but after a few stars the selenoid when bad againg any have any adeals why si this happenings and how can fir it
5 Suggested Answers
  • 279 Answers
SOURCE: riding mower won't start
Test before you replace! Check the ground cable. Make sure it is clean and tight. Check all connections for the same. I have to assume that you made sure the new battery was charged...Check all of your safety switches. Check the connection to the starter. Good luuck...Lee
Posted on Sep 14, 2009
mickey813
  • 472 Answers
SOURCE: Husqvarna LR130 burnt out starter
it has one but the way to fix it is to adjust the exahust valve thay should know that thats is how to fix that now the reason you cant find any thing on this is becous tecumseh is out of buisness thay have been out since 2008 i hope this helps you if not call me and ill help ya 918-7281822
Posted on Mar 08, 2010
Testimonial: "Thanks for the help. I'll check the exhaust clearance."
  • 277 Answers
SOURCE: The spindle with star shaped end that attaches
the reason it sheard off is because you did not put the blade on right.
you have to hold blade in position untill you turn nut all the way up and make sure blade has the star part in the blade when you tighten it.
you have to buy a new shaft most come with the lower bearing on them.
Posted on Jun 21, 2010
Testimonial: "Thanks for info. Recently aaquired tractor so previous owner must have misaligned the blade, but having just bought a new spindle, I now know what to look for."
  • 3074 Answers
SOURCE: Have and older style Poulan rider mower with a
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
Posted on Jun 05, 2011
I replaced the battery , and now the starter engages when I try to attach the positive cable
Yes, the solenoid gear teeth are jammed. For a temporary fix, you may try tapping on it with a hammer on the side of the cylinder to unjam it temporarily. Replace the solenoid. It's easier to install it and have the entire starter checked by a starter rebuild shop to assure our good guess solves your problem.
Apr 09, 2015 | Husqvarna Rz5424 Zero Turn Lawn Mower...
My husqvarna riding mower wont start it just makes clicking noise i replaced my battery and it does the same thing
Check for proper voltage at the starter terminal. If there your starter is bad.
Aug 26, 2014 | Husqvarna Garden
2008 dodge grandcaravan selenoid part
Assuming the battery and it's connections are okay, it sounds as though you have a bad solenoid in the starter. I replaced my starter, but I think perhaps you could get a solenoid rebuild kit from an auto parts store. When I pulled my old starter apart, it was obvious where the problem was. I hope this answers your question.
Mar 27, 2014 | 2004 Dodge Grand Caravan
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
My aero star wont turn over even when jump start it ignition makes a clicking sound i changed selenoid help
Your starter is at fault here. If you want to check it, just hit (not to hard!) your starter with a hammer on the housing. if it starts, the starter must be replaced.
Jun 05, 2010 | 1995 Ford Aerostar
Will not start
clean and tighten all connections from the positive cable all the way to the starter and selenoid connections too and try jumping the selenoid across and see if that kicks the starter over if it does that means the selenoid is bad
Jun 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My pick-up truck wont start it had a bad starter so i replaced the starter, then the battery died....but in the same day...i decided to just use other truck and give it a jump start, but my truck was only...
Based on your description, the starter selenoid is not getting enough juice (current) to pull up solidly. So, causes are:
1. Low battery voltage
2. bad connection of battery+ at the battery or at the selenoid terminal.
3. bad ground connection between the starter selenoid and the truck chassis.
If you want to bypass the selenoid, you can place a jumper cable on the "FAR" side of the selenoid (the side that feeds the starter). Then momentarily touch the other end of the jumper to the battery + terminal.
If the starter cranks, then you have confirmed the selenoid as problematic. Remove it and either replace it or disassemble and clean it.
Oct 13, 2009 | 1994 Chevrolet K1500
Won't crank--some kind of electrical problem
Disconnect the (battery) starter cable and check with a multimeter the continuity of the starter relay thru the relay terminals which connect the battery to the starter (key will have to be turned to start) -- if you get continuity, it's likely not the relay, but I'm with you, it sure sounds like the relay (solenoid).
P.S. Running a starter directly off a charger is a good way to burn up a charger.
Apr 28, 2009 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
