Question about Pioneer DEH-P2500 CD Player
The unit will not play radio or cd.
The Pioneer DEH-P2500 CD worked fine until my teenager used the vehicle one day. Strangely, since then the sound of silence has been with us. The stereo powers on & off like normal, face plate lights come on, all function buttons work also. Checked all speakers and wire connections; all o.k. Absolutely no sound coming out at all. Did the kid hit a mute button? I don't have a manual for the stereo. Any help would be appreciated.
  • 1 more comment
  • dboy254 Jan 05, 2009
    The time is displayed, all the function adjustments are visible and able to be altered, but no sound at all. The CD can be heard spinning, and is ejected upon pressing the button.
    It was done and still no luck, fuse out, disconnected power source-nada.
  • Michael Fisher
    Michael Fisher May 11, 2010
    Everything Shows Such As The Time And Everything?
  • 1,498 Answers
Hi there dboy,
As a rule, Pioneer stereos are aftermarket installs. Any other equipment installed with it?
For example, do you have amplifiers in the trunk powering your system? If so, a malfunction there would explain things.
If not, we start with the easiest first.
  • Press the A button (Audio Adjust). This cycles through the various adjustments you can perform.
  • Make sure Balance and Fader are centered.
  • Volume is up above 10 or so.
  • And of course, Mute is off.
  • Press the F button to cycle through functions again. Any difference?
If there is an ATT (Attenuator) on your model press it. This is another form of mute (why don't they just call it Mute?).
If there is no change, make note of any digits, characters or symbols appearing on the face. I don't need the obvious items like station or CD Track. It's the non intuitive items. (what's that squiggle there mean?)
I know you've done this already, but ask the prime suspect again if he did anything, however innocent, just prior to the meltdown.
I'm pretty sure this is an Auto Equalize option on your model, I just can't swear to it though.
Ask if the term 'Auto Equalize' rings any bells. If he shows any recognition, come right back with, 'Did you do it without the microphone'? If he cracks under the pressure, let me know. The EQ settings may be way high (off the wall high) and the system is protecting itself by not making any noise.
Comment me back with your findings and a bit more about the configuration. We may need to go a few rounds before we end the sounds of silence
Mike.
Posted on Jan 07, 2009
  • 716 Answers
I Know You Probably Don't Want To But Have You Tried Disconnecting The Battery Or Removing The Radio Fuse For A Minute? This Will Reset The Radio To Its Factory Presets.
Posted on Jan 05, 2009
Can I play a burned mp3 disc on my pioneer deh-p2500?
The specs don't mention MP3 anywhere, so the answer most probably is "No".
Apr 19, 2012 | Pioneer DEH-P2500 CD Player
Where is the reset button on the pioneer deh-p2500
there is no reset button on most pioneer cd players only pioneers that carry reset buttons are the in dash or double din players that play dvd's
Apr 15, 2012 | Pioneer DEH-P2500 CD Player
My Pioneer DEH-P3500 car stereo is having problems. The front panel buttons will not work at all... the radio was working, but the head unit would not let me change stations or make any adjustments. I...
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
Jun 21, 2011 | Pioneer DEH-P3500 CD Player
I just bought this truck with a pioneer DEH-P2500 radio and I don't know how to set the clock
According to the user's manual the following procedure is used to set the clock.
Manual is at this link http://www.retrevo.com/support/Pioneer-DEH-P2500-Car-Receivers-manual/id/23227dj392/t/2/
Here's the procedure indicated in the manual
1 Press SOURCE and hold until the unit turns off.
2. Press FUNCTION and hold until the clock appears in the display.
3. Press FUNCTION to select clock.
4. Press the Left Triangle or Right Triangle to select the segment of the clock display you wish to set.
5. Press the Up or Down Triangle button to change the digit up or down.
Jan 12, 2011 | Pioneer DEH-P2500 CD Player
How do I set the time on my Pioneer DEH-P2500?
Ok turn the system off to where only the clock is on, the green button lower left of the tuner buttons, press & hold down untill you see ((( ))) on the left & right side of the unit, then use the tuner buttons to a just the time !! GOOD LUCK ;-)
Dec 30, 2010 | Pioneer DEH-P2500 CD Player
PIONEER DEHP3500 ONLY VOLUME BUTTON WORKS PLAYS CD BUT BUTTONS DONT WORK ON CD EITHER RADIO DOES NOT WORK AT ALL
hi im using pioneer DEH-5750MP pnly sound is working and no other button is working ,cd is working fine but cant acces the radio as no other button is working
Jun 08, 2009 | Car Audio & Video
Pioneer DEH-2100, no power after alternator change.
Take the unit out of the dash. In the back of the unit, disconnect/remove the wiring connector. Underneath a little "flap" on the bottom of this connector there is a small red 10V fuse. That fuse had blown, and when I replaced it the CD?radio worked just fine.
Dec 13, 2008 | Pioneer DEH-2100 CD Player
Don't know how to set clock
General clock setting for Pioneer CD changers.
1)turn car iginition "ON"
2)press "SRC" and hold till unit turns "off"
3)press "audio " and hold until a blinking clock appears in display.
4)set clock by using the up , dn & right ,left keys on the faceplate.
5)turn unit OFF and ON again .
Oct 20, 2008 | Car Audio & Video
Wiring 6 X 9 Speakers
hi,
i m Ritesh Upadhyay , there is no sound driver in my computer.
so i want to download it.
Feb 18, 2008 | Pioneer DEH-P2500 CD Player
Pioneer DEH-P2500 CD Player Logo
278 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
