Question about Panasonic PT-51HX40 51" Rear Projection Television
Television picture gets larger
My televison screen keeps jumping back an forth from a larger image to the normal size image. This happens when the scene changes or when I change the channel. It sometimes stays normal for a while but then goes right back to changing sizes.
    Problem Solver:
  • 18 Answers
Your problem most likely is in your high voltage circuit, and the 160 volt radial lead capacitor is probably gone high ESR or changed in capacitence, this usually happens during bright sceens or sceen change.
Posted on Dec 27, 2007
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 12, 2017 | Samsung Televison & Video
I cannot put more than a few pictures on my jump drive to load into my digital picture frame. Also, I am unable to use my 4 gig jump drive on the picture frame; only one with small memory capabilities for...
The older memory frames could only read a few MEGS of memory sticks, not Gig. That could be a problem, these were made cheap so the latest and greatest parts were not used. Plus newer cameras are 4 mb per image rather then the 600K of older cellphones/cameras. That may be a problem too.
You can reduce the SIZE of the image to 800x600 rather then the 3K or 4K many cameras now take. There is a free program called PhotoFiltre (French company) that is very easy to use, free (no spyware) and only a few megs in size.
Install program, go to FILE OPEN, get image on stick, choose IMAGE - SIZE and erase the width, type in 800 click OK and it will adjust the height automatically. Then choose SAVE. Your file will be smaller but you will not notice it on an 8" screen. Do this with the rest, you will then have lots of room for more. WARNING.. do this with COPIES as you cannot "re-enlarge" them ! ! And as I have said since the 90's, alwasy have 2 backup copies in separate places. Those external drive are cheap insurance.
Feb 17, 2018 | SmartParts SP-DPF56E Digital Picture Frame
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need help adjusting the screen size on a Sony Trinitron KV-32FS13
try to adjust the yolk away from the picture tube
Jan 13, 2009 | Televison & Video
Televison
Common problem with some magnavox models. Check the site www.TvRepairKits.com for a repair kit.
Nov 18, 2008 | Philips 50P8341 50" Rear Projection...
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Colors off
I have the same problem, would like an answer.
Aug 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Picture Pulsating
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Dec 30, 2006 | Philips 60PP9202 60" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
