Question about Office Depot Ativa DQ60M Shredder
SPl 1506 Staples Shredder. pops fuse .
My Staples Shredder blows the fuse on the logic board immediatly when Plugged in, even if turned off. I believe the board is bad, where can one be obtained?!
2 Suggested Answers
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
STAPLES SPL-TMC 12A SHREDDER
There is an optical sensor that needs to be cleaned. It is usually at the middle of the slot where you put paper to be shredded. Use canned air to blow out both holes (one on each side of the slot).
Hope this helps.
Sep 22, 2016 | Staples Office Equipment & Supplies
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Sep 22, 2009 | Office Equipment & Supplies
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Office Depot Ativa  DQ60M Shredder Logo
171 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
quennie732
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
