Question about Watches
I have a Kenneth Cole KC3487 watch and everytime I wear it on my wrist it stop working after a few minutes
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
DarkWolfBomb
  • 80 Answers
SOURCE: Watch too large for wrist
you could ether drill more holes or get a new strap at a store that sells watches. you should of tried it in before you bought it. Just kidding
Posted on Jul 18, 2009
  • 2501 Answers
SOURCE: how do I set the time on a kenneth cole kc1296
I couldn't find any instructions for your watch but my wife has a similar one and it goes something like this.
There are two recessed buttons which need to be operated by a thin probe.
One of them is a "mode" button which changes the operation from normal to setting mode.
When you have pressed the mode button you should see the "hours" flashing use the other button to change the time (there may be two buttons, one up and the other down), when you ahve the right hour press the mode button again and the minutes will flash. Adjust as for the hours and when all is OK, press the mode button again to return to normal operations.
Good luck, have patience!
Posted on Mar 15, 2010
  • 2501 Answers
SOURCE: replacing the back on a KC3556 kenneth cole wrist watch
I suggest you contact the maker by going to their web site http://www.genevawatchgroup.com/ (this is the maker) and speaking to them. You are not the first to have this kind of problem and they should be able to sort it out for you.
Posted on Jul 15, 2010
Cracked glass on the dial
I have no idea how the things work in India, but any Kenneth Cole dealer shop must be able to sort your problem ( at least it is worldwide experience ). So, visit your nearest Kenneth Cole store and ask for help.
Do not forget to rate, please.
Feb 06, 2009 | Kenneth Cole RK5034 REACTION
KENNETH COLE WRIST WATCH MOD. CK1491
Yes, any of the Kenneth Cole dealers will be able to sort out your problem. Check the internet for the nearest Kenneth Cole store in your area and bring the watch to them.
Alternatively you can visit your nearest watch reapair shop and ask for help.
Feb 05, 2009 | Kenneth Cole KC1104 Wrist Watch
Unable to remove link from wristband of kenneth cole wrist watch
I am unable to remove extra links in kenneth cole reaction wrist watch
Oct 18, 2008 | Kenneth Cole 1213 Wrist Watch
Kenneth Cole Reaction Watch Model KC1450 digital settings
hold down mode until the time settings come up. the alarm settings show first, then press mode once more to set the actual time.
bing took me like 2 hours lol.
Jul 19, 2008 | Kenneth Cole KC1104 Wrist Watch
Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
Apr 05, 2008 | Kenneth Cole KC1104 Wrist Watch
Kenneth Cole KC3081
if you pull the crown out to the #2 position,then push the start/stop pusheryou will move the sweep sec. hand up to the 12 o'clock position. push in crown. Don
May 22, 2007 | Kenneth Cole KC3271 Wrist Watch
Kenneth Cole KC1169 not working
Please contact 17187298600X272 Linda Geneva customer service dept.
She will help y
Thanks
Tsai
Sep 07, 2006 | Kenneth Cole KC1169 Wrist Watch
Watches Logo
27 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
