Question about Kenmore 20722
My kenmore 20722 990 will not spin or drain.It will agitate though. It made a weird noise and then smelled like it was burning.
SOURCE: 98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Posted on Dec 13, 2007
the dr
  • 447 Answers
SOURCE: kenmore 80 series won't agitate or spin
Motor coupling is broken, this is a very inexpensive part and the new one is improved.......purchase one from any appliance part store and ill help with installation. There are quite a few tricks to axcessing the motor but if you handy its a cinch .
Posted on Jan 12, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 110.24642300 won't spin
This sounds like a typical symptom of a broken motor coupling. Click on the following link for step-by-step instructions on how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
These instructions will give you the necessary information to take the washer apart to get to the motor coupling to see if it has failed. A tell tale sign is black rubber dust particles under the washer where the drive motor is located. Usually the rubber bushing shears apart, or the plastic tines break off the coupling itself. If the motor coupling is broken a replacement can be found at searspartsdirect.com. Just type in your model number and the coupling can be found under the "Brake/Clutch/Gearcase/Motor/Pump" heading on the next page as item number 13. The part number is 285753A. This is a very simple repair job. If need further assistance, or have any questions please let me know. For quicker responses to your questions, please go to my profile and use the "Ask Me" feature. I hope this is helpful to you.
Posted on Jun 21, 2008
futureloginn
  • 734 Answers
SOURCE: Kenmore 90 series won't agitate, spin or drain
hello there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it. Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline
Posted on Dec 10, 2008
  • 8 Answers
SOURCE: kenmore washer drains but won't spin.
the first thing you should check would be that you had pressed the motor coupling far enough onto the motor shaft and the the shaft on the gear case the shafts should be flush with the coupling if not this will cause a bind on the motor and also cause it to have a hard time starting
Posted on Mar 25, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Kenmore 800 dryer burning smell and noise.
Access is from the front. Lint screen on top? 2 screws under screen, putty knife to release front clips between top and cabinet. Top folds back and 2 5/16 screws in top corners. Lean front towards you then lift up off lower hangers. Good luck.....
eric
Jun 06, 2009 | Kenmore Dryers
Washer wont agitate or spin
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 27, 2009 | Kenmore 43052 Front Load Washer
Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Nov 24, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Won't Spin the water out...
Hiya WRock04... would be nice to have make and model.. otherwise.. look to replacing the brushes in the motor if the machine has done relatively little work... 3-5 yrs in some cases... otherwise a new motor unfortunately may be required.. specially if you can smell burning!!
regards Faggly
Mar 19, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
