Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870 vacuum brushroll control doesn't work
I cannot get the brushroll control on our Eureka 4870 vacuum to work. It doesn't stop the brush roll from turning.
  • 4 more comments
  • Anonymous Jan 24, 2009
    Mine will not shut off automatically when put in the upright position. I called Eureka, but they only offered to give me a service location. I am not going to pay someone $100 to fix a vacuum I paid about 125 for. Any ideas?
  • Anonymous Jan 29, 2009
    I have the same problem. It worked fine for the first year or so but has not since, even after replacing the belt. I'm stumped.
  • Anonymous Mar 13, 2014
    i had my vacuum about 10 days. while cleaning i shut it off then went to turn it back on and it wont turn on
  • Anonymous Mar 14, 2014
    Brush roller will not shut off, even with vacuum in upright position and on hardwood floors
  • Anonymous Mar 15, 2014
    y Eureka stopped working while I was vacuuming
  • Anonymous Mar 19, 2014
    the brushroll head doesn't stay in the down position
Use two hands to presscontroll button upward until it snaps in place.
Posted on Jan 06, 2009
    New Friend:
You really have to push hard on that switch for it to engage; both thumbs; I'm 190 pounds and I still had to apply a lot of extra pressure; poor design for a great vacuum cleaner
Posted on Dec 27, 2009
SOURCE:
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brush turn in hose mode
please go to : http://www.eureka.com/en-US/Customer-Service/Videos/
see the video and troubleshooting guide with common sense,for repair.
this problem normally come : a) belt is broken or worn, need replace b)brushroller blockage, clean it and fix it. c) pulley -motor defective or repair.
GOD BLESS YOU
Jul 15, 2012 | Eureka Smartvac 4870 Bagged Upright Vacuum
Have a Eureka "the boss" smartvac, won't pick up anything when I try to vacuum carpet. Any suggestions on how to fic this problem?
1st) make sure your yellow dial at the top by handle is in floor position
2nd) make sure your brush roll spins when handle is reclined in operating position. (disengage brushroll control by flipping the "switch" towards you)
3rd) check belt to make sure it is not broken
4th) check the brush roll for debris caught in it
5th) check lower hose
Aug 12, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brush roll belt stops turning when in position to vacuum. Does turn when vacuum is turned onto side. Belt is in tact, brush roll is fine. What's going on?
I think I know what the problem is with your machine. It's a rather lengthy repair, and I'll be happy to photograph it for you (like I do on most of my Fixya answers), but I'd like to know before doing all of that if you still need help, or if you've already fixed it.
Thanks,
CJ
Apr 06, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brushroll engagement at carpet mode doesn't always work eureka 4870
Is the brushroll ends turning freely? if not then replace it, There could be a problem with the belt, or with the idler clamp asm. Sometimes they get clogged up with debris and won't work properly, try cleaning it. This is what lets the brush turn or not turn, depending on the position of the switch.
Mar 09, 2008 | Vacuums
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
1,510 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
