Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
I know I need to change the convergence IC's in my phillips 55in.
I have the new convergence IC's(STK392-120) for my phillips 55in. T.V., model #55PP93 5217. I just don't know how to replace them! I looked at T.V. but do not see anything that looks like the new convergence IC's. Can you please help me, I am sick of the bubbles at the top and bottom of my screen!?! Thanks!!!!
  • Anonymous Feb 12, 2009
    i hace the same problem. and would really wanna get this fixed
  • Philips Master
  • 3,459 Answers
Next time save yourself the headache and get a kit with all the parts and photo instructions from www.TvRepairKits.com
Posted on Apr 22, 2010
Here is a lnk to get the service manual 188 pages save it then rename the file ext .pdf
Posted on Aug 09, 2009
  • Philips Master
  • 19,396 Answers
Follow Instuctions on this website.
Buy the replacement here
Also better buying a service manual before starting the repair.
Posted on Jan 05, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
Looking at the circuit board from the back of the tv, the board on the left (ssm) there is a big heatsink on the right side of the board it has two STK392-120 ic's. When you replace these ic's you will also need to replace 12 6.8 ohm 1 watt resistors.( they will have 6r8 stamped on them.
Posted on Feb 05, 2010
Can I have the part # for convergence ICs for Phillips TV Model 51pp9200D/37?
IC convergence number: STK392-120 or STK 392-150 Will work correctly. Any question, please let me know.
Aug 04, 2011 | Philips 51PP9200D Television
My magnavox HDTV model #51MP392H/17 the year on the back of the tv is 2004 the picture on the screen looks like its in 3D how can i fix it myself. I tried a new cable box it only worked for a few minutes...
The convergence ICs and resistors have failed. You will need to install a convergence repair kit. The Phillips DPTV305 chassis convergence repair kit is the correct one for your magnavox. Its available at www.tvrepairworld.com and the kit contains the 2 ICs and resistors and the CD with repair instructions.
Jun 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
Is this a Convergence IC chip problem?
yes this is a bad ic
here is my tutorial.. most of these use a stk392-120 and i would replace both of them
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 14, 2010 | Philips 55PP9352 55" Projection Television
My ws55511 55in has double vision and red shadows.
I don't think that it is the convergence module, but, your symptom sounds like a damaged convergence IC. Board level repair your set would be very expensive and the board may not be available any longer.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Oct 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55859 55in Rear Projection CONVERGENCE won't correct
HELLO YOU FIRST NEED TO UNPLUG THE SET , THEN TAKE OFF THE BACK OF THE SET. AND LOOK FOR TWO LARGE SILVER HEAT SENK'S THE IC CHIP'S WILL HAVE STK-393-110 ON THEM.!!! WILL BE SCREWED TO THESE HEAT SENK'S WITH SCREW'S AND SOLDER TO THE BOARD ON THE BOTTEM OF THE BOARD,!!! WELL "GOOD LUCK"
Nov 09, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Phillips 55in widescreen hdtv
you convergance amp is is shot
Dec 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
948 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
