Question about Symbol Computers & Internet
My Symbol scanner LS2208 is unable to read code 93 codes of 8 or 12 digit length, whereas it can read 5 digit length without problem. Why is that and how can it be fixed?
  • 25 Answers
SOURCE: NOT SCANNING CORRECTLY
I'm guessing you are using the USB version and the power that comes from the comuter via the USB cable.
It is quite likely that the problem you are having is due to power sag. .500ma is the limit from P.C. s
Do you have a 15 foot cord on there? If so try a 6 foot cord. Sagging still occurs with a 6 foot cable ...but only half as much. If the problem goes away you are on the right track.
I have a cable (I should say Motorola has a cable) with a separate power supply that should fix the problem.
Posted on Jan 05, 2008
tatsuto
  • 13 Answers
SOURCE: barcode scanner Symbol LS2208
I had the same problem with LS4278, you need to configurate your keyboard and scanner in the same regional and language options
Posted on Oct 20, 2008
SOURCE: LS2208
Symbol has confirmed that there was a batch of scanners sent out with defective lasers. Call them at 800-653-5350 for a replacement. Have the scanner handy to give them the serial number. They were very helpful.
Posted on Jan 20, 2009
Yogger
  • 117 Answers
SOURCE: Symbol scanner LS2208
Hello Roco,
you need the Intelli Stand to activate this function. The scanner can recognize it and activates the Hands-free mode himself. Until you reoved it from the IntelliStand again.
Posted on Dec 05, 2010
Yogger
  • 117 Answers
SOURCE: Switching rules Symbol LS2208
Hello Jonathan,
you would need to assign the rules to a specific ruleset. Then you switch between the ruleset to specify which rules are active at the moment. Please see the ADF chapter in the Reference Guide for LS2208 for the barcodes http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Posted on Dec 07, 2010
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
How do i get my scanner to do "enter" without
Hello Severiano,
this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document. https://docs.symbol.com/attachments/ADC-01244.doc
Aug 02, 2011 | Symbol LS2208 Handheld
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
Hi my name is christian canola and i purchased a symbol ls2208 barcode scanner from geminicomputers and i downloaded the program 123 scan2 for my barcode scanner and i click on my scanner is connected via...
Hi Christian, if your scanner was manufactured before February 2010 it may not be able to communicate directly with 123Scan2 so you wont be able to upgrade firmware with the program, but you will still be able to use it to create configuration sheets. These are the only two uses for 123Scan2.
To create a configuration sheet without "finding" the scanner click Create New Configuration then choose My scanner is NOT connected. Select the LS2208 and click on the blue firmware button to get into the configuration. When you have completed your configuration click the Print bar codes selection at the top of the window and when the file comes up be sure to click on the Bar code formatting menu and change the Bar code type to 1D One setting per barcode if it is not already there. Older scanners will not work with concatenated 1D barcodes where 123Scan2 puts more than one setting into a barcode.
Feb 12, 2011 | Symbol LS2208 Handheld
How can i progamm the 2208, so it will scan code 39 and code 93
The Quick Start Guide has a Default Barcode. Scan that. Code 39 and 93 should be on by default. If not download the Reference Guide and there are barcodes in that manual that enable/disable all symbologies.
Dec 05, 2009 | Symbol LS2208 Handheld
I cannot scan code93
Code 93 is not enabled on default. Scan the Enable Code 93 barcode from Adobe page 190 of 342 from the LS2208 Product Reference Guide. You didn't say which scanner you have but most Motorola scanners use the same barcodes. If the scanner does not accept this barcode then look up the PRG for your scanner and find the barcode in that manual. You may also need to scan the Code 93 Any Length barcode from the next page if your barcode is less than four characters.
Oct 23, 2009 | Symbol Computers & Internet
I have this situations: my system don't read any code begining with 0, please need this configuration for symbol LS2208. Thank you.
Your scanner must have been delivered with a "Quick Start Guide".
All you need to do is to scan the following barcodes from thar Guide:
1.Set Defaults
2. Scan Options
3.<Data><Suffix>
4.Enter
5.The barecode for whatever type of connection you use (RS232, Keyboard, etc.)
Jan 30, 2009 | Symbol LS2208 Handheld
LS2208
Oct 06, 2008 | Symbol LS2208 Handheld
Computers & Internet Logo
51 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
