Question about Sansui VRDVD4001 DVD Player/VCR
Taping VHS to DVD
How do you tape VHS to DVD?
This unit does not have a dvd record function. you will need a dvd recorder.
Posted on Mar 04, 2008
SOURCE:
AFTER TAPING FROM THE DVD TO THE VHS I AM EXPERIENCING SNOW WHEN I PLAY BACK TO WATCH WHAT I TAPED HOW CAN I GET RID OF THE SNOW
You can use a dry or wet cleaning cassette for your VHS heads, this can help you to get a better image from your tapes but also check if the magnetic tape of your cassettes aren't too worn out.
Feb 26, 2011 | Zenith XBV443 DVD Player/VCR
Taping VHS through HD Set Box
as i am aware of you can only tape sd programs on to vcr and not hd.
May 26, 2010 | Emerson EWV403 VHS VCR
Problems transferring entire VHS tape contents
Just continue what your doing in previous just save the remaining minutes maybe the limits was approaches.
May 18, 2009 | Diamond Multimedia ( VC500) Video Capture
Finalizing DVD-R fails, rendering Verbatim disc non-readable
You might try finalizing the disc in a PC using IMGBURN or other DVD recorder software. It couldn't hurt...
tom
Jan 09, 2009 | LG DR787T DVD Recorder
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Recording purchased vhs tape to dvd recorder.
How old is the VHS tape? I've had success recording older movies, but the newer ones have encryption to prevent duplication of them. I've even tried playing them on another VCR and transmitting the signal with a wireless audio/video transmitter but unfortunately the encryption is still there. If you can copy the tape to another tape, then it may not have encryption. If that's the case, check you A/V inputs to see if you have them setup right.
Jun 12, 2008 | Aspire Digital AD-8091 DVD Recorder
Unlock Samsung DVD-VR357
A time-base corrector device will do the job....accordianman
Feb 16, 2008 | Samsung DVD-VR357
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Recording tv from a vhs player
sound like you have a dirty video head, try cleaning the head with some isopropyl alchol. if it does not fix your problem, then you will have a bad video head. good luck
Feb 15, 2007 | Samsung DVD/VHS/MP3/SVHS Playback
Sansui VRDVD4001 DVD Player/VCR Logo
46 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
