Question about Canon MP970 Photo All-In-One InkJet Printer
Blue tooth communication problem
When i try to print something i get an error stating check if printer is on , check if printer is connected
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructions.
Hope this helps. Bud
Posted on Jan 28, 2009
Printer is in "error state" will not print.
Did you use a new factory cartridge? If not the cartridge may be shorted.
Jun 23, 2016 | Lexmark S415 - multifunction fax / copier...
My printer is not communicating with my computer it is with my phone thou.
If it is communicating with your phone you are on a Blue Tooth connection. You most likely will have to hook up your computer by Blue Tooth as well. I don't know what type of printer you have but you may have an option to set up both types of connections but it will be in the printer menu under set up/wireless/network
Nov 11, 2015 | Office Equipment & Supplies
Why won't my Epson 280 printer work?
Try new / different cables. If wireless, make sure to follow all of the connection instructions to your router.
Aug 19, 2014 | Epson Office Equipment & Supplies
I want to connect my printer by blue tooth
I don't know of any that connect that way - USB, ethernet, or wifi only
Oct 20, 2013 | Epson Stylus Office Equipment & Supplies
How to print from iphone 5 to canon MX860 what app is needed?
If the printer is a wifi or blue tooth printer, you should not need any apps. Just make sure your phone and printer are connected via wifi or blue tooth and it should print whichever document you need printed.
Mar 16, 2013 | Apple iPhone Smartphone
Command error on epson 9600
Are you sure it is a 'command error' and not a 'communication error'. I could not find anything on a 'command error' but did find this on a 'communication error'.
Q: Why am I getting a communication error when I try to print?
A: Check the following if you are getting a communication error when printing:
Make sure the type of driver you installed matches the ink type in the printer. Verify the ink type by checking the part number on the ink cartridges.
Make sure the printer interface setting matches the connection type you're using. By default, the printer interface should be set to Auto, which supports all connection types.
Check the physical cable connection and make sure the cable is not be longer than 10 ft. You may want to replace the cable.
You may also get communication errors if the printer name is not set correctly. Contact EPSON at (888) 377-6611 or (562) 276-1305 to get instructions on how to verify this.
You might want to check to see if you have the current drivers for your printer and operating system; a new driver can be downloaded here.
Trust this is helpful.
Dec 14, 2010 | Epson Stylus Pro 9600 InkJet Printer
Scan was not successful
Try a new USB cable. Directly connect the printer to the computer if using a hub or print server. Try plugging the unit into a different USB port. Scanners require bi-directional communication with the computer and are much more sensitive to anything that may interfere with that communication.
Do you hear any sounds that indicate that the light source is warming up and moving in the unit? Check if the scanner has a travel/shipping lock and unlock it. If it isn't moving, then you may need to service the unit.
I hope this helps.
Apr 02, 2010 | Lexmark X9350 All-In-One InkJet Printer
It just won't print!
try to make un-install drivers for the printer, then reboot and install driver agin.
I think, it might be your driver currepted and cause this problem.
Please post your feed-back.
Gud-luck
Iqbal
Apr 15, 2008 | Lexmark X3480 All-In-One Printer
I Mate Jam Blue Tooth sync
dear sir , when you try to connect using bluetooth you have to define the COM port from the control panel >> bluetooth devices then you add a new port and remember the number of it . then open Activsync. click on file >> connection setting then check this option : allow connections to one of the following .. then choose the COM that you just add it from the control panel. it will works now
Jul 03, 2007 | i-mate JAM Pocket PC
Canon MP970 Photo All-In-One InkJet Printer Logo
80 people viewed this question
old marine
old marine
