Question about Acer Aspire 5050-3242 Notebook
HI NOT ABLE TO TRANSFER THE VIDIO ( S VIDIO )TO TV SCREEN.....IT WAS POSIBLE PRIVISIOLY
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    Are you changing the input on the TV, as well as using the function keys to change the output on the laptop?
S video port compaq presario
The S Video port is driven from the GPU which must have drivers to work it if you have a picture on your laptop screen. S Video is unprocessed VGA.
Nov 30, 2013 | Computers & Internet
R79kilama036@gmail.com
virus scan your machine and check if the harddrive is full of data.if full --transfer some big files over to external harddrive and see if this helps. can also be a lack of ram (to little ram)
Oct 24, 2013 | Computers & Internet
Can I connect my Dell Studio 1558 to my 55
I am assuming your 55" screen or tv
YOu can connect you dell via a RGB part if you tv has one
however you laptop does not have ehether a S vidio or hTMI port
so that means you can't connet to most screens
Mar 16, 2012 | Computers & Internet
Will not turn on complectly black screen
the lights are on? the cooler is on? if so try to conect it to a extenal monitor o lcd tv that got vga input.
if the image is on is posible that u got a problem whit display.
if no lights and no noise....u can try to take out batery and try just whit ac power
if is not working try to go to a center or something
i hope that help
Sep 22, 2011 | Computers & Internet
I conect my lenovo laptop Y 410 with Panasonic THP42C10 D for Vidio There are no sound in TV
Hi dr_piyushpat,
I see that you conencted your Lenovo Y410 to a Panasonic THP42c10 LCD TV, see details below.
*The Audio will dpened on what cable connection you have from the Laptop to the LCD TV,
*You have Y410 I do not think that HDMI will be an option.
*I believe that you are using the VGA port on the Machine for an extended Video.
*The Audio will really not be coming out of the Panasonic TV if you are using a VGA cable since that is only for Video you will need an audio cable Jack that will relay audio from the Laptops Audio Jack to the Audio Jack of your Panasonic TV thsi is the only way you can get audio out from the Laptop since you are conencted using a VGA cable.
* do not think that HDMI is present on your Lenovo Y410, but if ever you may have that connection/port the way to get Audio from an HDMI conenction is to change the audio PLayback properties and selct HDMI as the default device for the Audio to work using HDMI.
I hope that this helps.
have a nice day,
mvincentc
Feb 13, 2011 | Lenovo 3000 Y410 Laptop
Colour Distortion
I got the same problem, all you have to do is turn off the laptop on the back of the laptop & switch it back on
Feb 12, 2010 | HP Pavilion dv6000z Notebook
Screen has a white bar across the center left to right about 1"" wide. Re-Installing vidio driver did not help. What is wrong?
The display sounds to be bad.Maybe the inverter but most likely the display itself is has gone bad.
Oct 05, 2009 | IBM ThinkPad T40 2373 Notebook
Dell Latitude D600 PC Notebook
your s-vidio out on the laptop only transfers vidio, you need to use a headphone to rca jack cable pluged into your headphone port on laptop and plug rca into back of tv or vcr or s-vid converter box
May 31, 2009 | Dell Latitude D600 Notebook
The S Vidio output does not work to hook up a TV.
Try to connect everything than restart computer,it might detect the tv automatically.
May 23, 2009 | Acer Aspire 5920-6335 Laptop
Acer Aspire 5050-3242 Notebook Logo
60 people viewed this question
Brian Sullivan
Brian Sullivan
