Question about Brother Office Equipment & Supplies
Brother lc980 black ink will not print
New cartridges installed but black will not print
SOURCE: black ink won't print at all
It worked!!!
I actually had to run the clean process about 10 times before I saw even a little bit of ink on the page, so ran it another 5 or 6 times, and now it's printing perfectly again.
I'm amazed, and thankful. I thought it was a goner.
Thanks.
Posted on Dec 16, 2007
  • 310 Answers
SOURCE: New ink cartridges not printing
there are 4 possibilities here.
1) the ink cartridge although appearing OK may have dried out or be faulty. If you have just purchased the cartridge take it back to the place of purchase for an exchange/refund.
2) not all the packaging has been completely removed. To check this remove the cartridge from the printer & make sure that ther is no plastic wrapping still on the cartridge.
3) the print nozzle is blocked. to check this go to control panel: printers & faxes right click on your printer then select properties. select the maintanence tab then do a nozzle check test. If the black does not print try selecting the clean & then deep clean items, If this still does not work remove the cartridges from the print head & see if using a soft lint free cloth you can remove any ink build up fom both the print side & the cartridge side of the print head. If this still does not work number 4 will apply.
4) your print head has failed. If u have warranty means better replace it..
Posted on Sep 07, 2008
SOURCE: Black ink cartridges not working.Have tried two
I had inserted a new black ink cartridge in my DCP - 585CW Brother printer and it does not print, the coloured ink workks but not the new black ink?
Posted on Dec 21, 2009
Sebin
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
SOURCE: Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Posted on Feb 14, 2010
I ran out of the other color cartridges, and just bought a new black ink cartridge only. So can it work without the other color cartridges, and only on the black ink cartridge, because every time I try to...
No many of the printers will need to have both the color and the black cartridges to work...
You will have to purchase and install a new cartridge to get it working correctly.
heatman101
May 17, 2011 | Brother MFC-290C Printer
I changed the ink cartridge the black one but it still says cartridge empty I unplugged it and it still sais the same thing
My MFC-420CN acts up occationally. Remove the new cartridge, hold it as you would to install it, Rotate it to the right about 45°. Snap it with the back of a finger (dislodges any air bubbles in ink feed). Reinstall cartridge (ensure it is fully seated. This works for both Brother cartridges and the eforcity cartridges I've been using for the past couple of years. HTH
Lou
Oct 17, 2009 | Brother MFC-685cw InkJet Printer
Ink cartridge full but won´t print
This might need to be reset.
Here' how...just follow the instructions..
moz-screenshot.pngThere's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Oct 02, 2009 | Brother HL 1440 Laser Printer
New Brother won't print black
Take the printer back to where you got it from and exchane it for another one...
Jul 08, 2009 | Brother DCP 165C Compact Color Inkjet...
Black ink will not print (new out of box).
If cleaning doesn't work you should talk to your retailer or Brothers support. Don't think they can expect you to use up all ink cleaning cartridges when the machine is straight out of the box..
Jun 01, 2009 | Brother MFC 6490CW InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Balck ink not working
brother mfc-5440 ~ same exact issue on not printing the black AFTER purchase new cartridge (again!) ~ i should have checked here first.... NO MORE BROTHER printers in our future & will tell all our friends, too....
Mar 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer problems-------
Have you tried replacing the black ink cartridge with a new one. The new one you installed could have a defect.
Feb 28, 2008 | Computers & Internet
108 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
