Question about Dell 3100MP Multimedia Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing pictures of varying images., and occurs when I use dedicated church projection software program or desktop images.. It is not present when i use a white background image in PowerPoint . When I bought the projector the lamp use was about 130 hours. I`m not sure if the buldb is going but warning lamps had not lit.
  • 93 Answers
Sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Posted on Feb 09, 2009
My church screen projector shows little bubbles on the screen and every time I put up worship songs or photos on the screen in church, you see bubbles, and It does not look good
If it's an LCD base projector, then you'll need to clean out the dust particles that have accumulated on the LCDs that will require you to open up the projector, which I wouldn't recommend if you're not too familiar as there are many components inside.
Jun 22, 2015 | Office Equipment & Supplies
Hi, is Dell 3100MP Projector is compatible with windows 7 laptop. I am Having message " NO SIGNAL, CHECK VIDEO CABLE" with Windows 7 but with Windows xp, the same projector works fine. Can anyone...
In most cases this problem is cured by enabling the external VGA (or monitor) ouput on the laptop. The quickest way is to reboot the laptop with the projector turned on and connected. Usually the laptop will detect an external display is attached and enable the port.
It is also possible to manually enable the external display port. It varies from laptop to laptop but look for the "Fn" key at the bottom left of the keyboard, usually coloured green or blue. You should see a row of icons on the top row of "F" keys which is in the same colour. Look for the one which is either a monitor, or possibly says LCD or CRT.
Hold down the Fn key and press the key you located in the last step. There is usually a delay of a few seconds and then you'll find something may happen. Usually the external output will be turned on alongside the local (laptop) display. Repeatedly following the last step cycles through all available configuration options, including both on, local on, local off, external on, and external off.
This should fix it. Make sure that the correct input is selected on the projector whilst doing this. It will be labelled on the projector and it should display the same input message on screen.
Feb 21, 2011 | Dell 3100MP Multimedia Projector
Our church projector model PLC-X456 and serial G4YO4536 shuts off occasionally. I replaced the bulb but it shut down again (during services). Someone mentioned that they did not hear the fan running. I...
If your church recently purchased it, it would be better to refund your money or get a replacement. Its somewhat difficult to find parts for projectors, and when you do, its usually cheaper to replace the whole unit.
Jan 26, 2011 | Sanyo PLCXU350 LCD Projector
It started making a loud noise and it suddenly
it's the colorwheel. part# 70.81R26GR01. you can get the part and do it yourself, or send it to a service center. either way, av solutions in ny is pretty good (www.avsolutionsny.com). they can either get you the part or replace it for you.
Oct 30, 2009 | Optoma MovieTime DV10 Multimedia Projector
Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Jun 19, 2009 | Dell 3100MP Multimedia Projector
No Sound
check the setting of sound.. if its okay check the speaker wire connector or the chips.. but be care full for opening if you can open and fix no problem..
or look qualified technician for projector
Feb 03, 2009 | Dell 3100MP Multimedia Projector
Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Can't get computer images to project
Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
Bad SMT connector on main board
mmm. a very small tipped soldering iron
while working under a mantis pcb magnifier.
you'll need a steady hand.....
don't however try to remove the sm connector, this will probably only wreck the pcb. try to use small wires to make the connections and bypass rather than try to rescue the connector.
Feb 25, 2008 | Dell 3100MP Multimedia Projector
Shrinking Screen Display
It can be a problem with teh bulb...you may want to make sure that the fan is not shutting down when you power off the projector becsue that may shorten the life of the bulb,...the fan should remain on for a while to continue cooling off the bulb....it probably won't hurt to have use another fan pointing to the projector while in use...
Apr 30, 2007 | ViewSonic PJ458D Multimedia Projector
Dell 3100MP Multimedia Projector Logo
559 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
