Question about Honeywell Programmable Thermostat Heater
Fan runs indefinitely after heat shuts off
Last month we had a power outage that fried our thermostat and one of our breakers, so we replaced both. The heater works now, except the fan continues to run forever after the heat turns off therefore blowing cold air. The honeywell tech people say I have everything wired correctly, so I really don't know what to check now. We've been using the emergency heat since that seems to work just fine, but were in for a shock when we got our electric bill. Can anyone point me in the right direction?
  • 14 more comments
  • Chellynae Jan 05, 2009
    The thermostat is RTH3100C, which is a Honeywell Non-programmable Digital Thermostat. I believe our system is a Trane. Thanks so much for looking and giving any advice you might have.
    No the fan does not run constantly when it is set to E-heat. It just runs while heat is on and shuts off when it is supposed to.
    For the thermostat, yes. I have the installation guide.
    The entire system came with the house though, so I don't have any info on that. It is only a few years old though.
    Ok. Checked the settings according to the guide, and all is correct.
    Yes. Although, it's not consistent. Some days the stupid thing never shuts off, and others it seems to work fine.
  • Chellynae Jan 06, 2009
    Hmmm, I never thought of that since it is brand new, but that's entirely possible. Thank you so much for your help! I will replace it and see if that takes care of the problem. Thanks again!
    Would love it if you would post this as a solution so that I can rate you as very helpful dwkcool!
    The heater worked just fine yesterday on regular heat, but this morning when I woke up it was chilly and is blowing cool air again. So, it seems like maybe the problem only occurs after it has been on for a while. Do you still think that could be thermostat, or do you think something is actually wrong with the heating element or something else?
    I don't think so. The E has a black wire in it and the Aux has the white wire. Do I need a jumper?
    Well, that makes absolute sense since it only seems to happen after it's been running for a while. I will put in a jumper tonight and see if that helps. I have a feeling that it will! I'm in Texas though and the weather has already swung to warm, so I will have to wait for the next cold front to know if it worked for sure. Thank you so much for your time and expertise! You have no idea what a blessing it is!
  • dwkcool May 11, 2010
    sounds like you might have a bad t-stat
    has the problem been the same since you put the t-stat in
    check your set guide for the t-stat on the setup program
    do you still have your setup papers
    the fan does not run forever on E-heat
    what style honeywell is it and what brand system do you have
  • 96 Answers
Yes I have replaced a couple of t-stats lately (honeywell)
Posted on Jan 06, 2009
  • dwkcool Jan 06, 2009
    did you put a jumper wire in from E to AUX where your white wire connects
    yes so when it goes into defrost it will have enough backup heat to keep up with the house
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Runs but will not heat. Power outages in area over last few weeks.
If the dryer was running during an outage, even with a very brief flash there usually is a power surge when it comes back on. If everything else seems to work okay it's possible that the heating elements got fried. You can check them with a voltmeter. Also check to seek if the dryer has overlaod protection. Most have a reset. One other thing that could happen, the breaker is defective. That you can check at the back of the dryer where the plug cable attaches to the dryer.
Apr 09, 2011 | LG DLE2516 Electric Dryer
After a power outage my T8011R display will not come on. Breaker is on and the auto fan works--so there is electricity to the thermostat. Is it fried or is there a reset or fuse that I need to address?
Hi, if the stat is working and running the fan, what has happened is the circuitry is faulty that shows the digital display. Before we are certain this has happened, check to see if the stat has batteries in it. Pull the front cover off and check. If it does, replace them and see if the display returns. If it does great! If not its the circuitry in the stat and will need to be replaced. Keep me posted.
Shastalaker7
Jan 17, 2010 | Honeywell Electronic Programmable...
AC wont kick on....
The first thing to check is your breaker box. There should be one double breaker for the air handler unit, that's the inside unit, and one double breaker for the compressor, that's the outside unit. Check both breakers. If you're not sure if they've be thrown, click them toward the outside of the breaker box (off position) and then click them toward the inside of the breaker box (on position). If the breakers are on and you still are not getting any A/C take a look at your compressor, (outside unit). If the fan is running at least you're getting power. However, your compressor down inside the unit may not be getting power or it may need to be replaced. The compressor has a start-up cap. If this cap goes bad or the wires from this cap fry or corrode away, this will also keep the compressor from starting but the fan will still run. If the fan is not running it could be caused by a faulty relay inside the compressor cabinet. This relay is supposed to open and close based on a low voltage signal from the thermostat. I believe it's roughly 24 volts. This relay switches on and off the 240 volts for the compressor and the compressor fan. Often this relay goes bad or the wires leading up to it fry. If you?re going to work on the unit yourself make sure all power is shut off. There should be a shutoff switch on the outside wall near the compressor. I?d also shut the breakers off.
Jun 12, 2009 | Honeywell Programmable Thermostat Heater
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
309 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
