Question about Pyle PLA1000 Car Audio Amplifier
I need help!!!
I am installing my amp and when i hook my remote wire up the power light stays on for about 2 to 3 sedconds then goes off; and the protect light comes on. Please help. How do i fix this problem?
Look good of your conection
Posted on May 27, 2007
    Novelist:
    Champion:
  • 219 Answers
If this is a new amp then you may have your speaker load wrong (low). If this is a used amp then you may have a blown output section. This is of course assuming that you have a good ground and hot wire connection and wire size. Good luck.
Posted on May 24, 2007
Stop the powers alimetation of amplifayer 2hour end gou after
SOURCE:
What's the Motorola box under my back seat Chevy trailblazer 02 also I'm hooking a amp to battery where do I connect the amp turn on wire I guess it be remote wire
The motorolla box may be remnants of an old disk changer for the stereo. With an amp your power wire goes into the positive wire that goes to your battery, your ground wire will be connected to some bare metal close to wherever you decide to install the amp, and the blue remote wire will be connected to the remote wire that in on the wiring harness of your aftermarket radio ( I'm sure your not installing an amp with your stock radio). Good luck I hope this helps
Oct 05, 2014 | 2002 Chevrolet TrailBlazer
Jl500 amp... Been hooked up the same way for years. Power wire from battery with an inline fuse which goes back to the power block which goes to the amp. Perfect ground and remote wire to the deck. And RCA...
well the nasty spark it shoots its because you r to first connect negative first always and than positive or check ur main cable/fuse that is connected to your battery inside the fuse box its actually pretty easy to find just follow the positive red wire from your battery till u get to the fuse box it looks like its connected to negative and positive, check it it may be the problem(inside the fuse box), if it isn't you should check the main source of battery recharge which is your alternator it may be going bad
Aug 01, 2012 | Car Audio & Video
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
How to hook up my amp?
first what are u trying to push, second, the amp is 150w rms. that mean constant power, and 250 @ 2 ohms, now you have power, gnd=ground, and remote<- that turns the amp on when you turn on the car, power or the + sign is what gets connected to the battery, then the ground/gnd or - sign is what gets screwed to the metal of the car, then there is the remote this wire gets connected to your radio, or to any accessory fuse, i.e. lighter, radio fuse, or if you have an aftermarket radio, then it gets connected to the blue with white stripe wire, that will be the amp turn on wire.
You will need red wire about 17ft, black wire about 1ft, and 15 to 16 ft of remote wire, or you can just by an amp kit, that will be easier.
now that the amp is done, time to do the speakers;
You have + and - on the amp, and your speakers have the same signs as well, just make sure when you wire the speakers + goes to + and - goes to -. if you need more help call me @ 6314330567
Feb 19, 2010 | Car Audio & Video
Protect light comes on, no power
Hello patrick_h_mi,
You'll also need a remote turn-on source for the amp to operate. Normally, this is a blue or blue/white wire from your head unit, but for test purposes, you just need 12V to the "remote" terminal on the amp. The amp should power up without speaker inputs or speaker connections, but it is not recommended.
Hope this helps.
May 28, 2009 | Infinity 7540A Car Audio Amplifier
I recently installed a amp to my sound system I have a pioneer deck when hooking it up everything works but when I turn it off the car theamp light stays on I check everything I think it is my remote wire.
You are correct!
If you have a volt meter or a test light you can use it to see if you have some voltage on the remote terminal on the amp.
If you do not have either of those items, just disconnect the remote wire and see if the light goes out.
If the light goes out, you have voltage coming from your radio that is keeping the amp turned on, that is normally a problem with the radio. The remote output of the radio may have a shorted transistor in the circuit.
If the light stays on, you have a problem with the amp. It is rare to have an internal electrical problem with an amplifier and the amp still works normal. That is not to say it can not happen, there may be a component that is shorted in the turn-on circuit of the amp that is isolated to the turn on cicuit only, and it keeps the amp on all the time.
This will become a big problem soon if not repaired. If the amp is staying turned on even when the car is off you will drain your car battery rather quickly. Most amplifiers will draw between 1 amp and 2 amps of current with no signal applied, this is called the idle current.
Find out which unit is causing your problem and take it to be repaired, it is most likely an electrical problem that will need good electrical troubleshooting skills to locate.
If you need any more help with this feel free to ask, with the model number of the unit at fault I can even find you some likely suspects to be checked.
Don't forget to give me a "FixYa" if this information turns out to be helpful.
Jun 19, 2008 | Car Audio & Video
Auto amplifier installation
Does the new deck have a blue wire for remote and a blue/white wire also? The blue one is for a power antenna and shuts of when playing discs or axillary inputs. The blue/white is for power amplifiers and stays on when the deck is on. Also be sure the remote wire that goes to the amp is not pinched and grounded out to the frame of the car. Let me know, and be sure to leave feedback or I don't get paid.
Sep 30, 2007 | Car Audio & Video
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Pyle PLA1000 Car Audio Amplifier Logo
52 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
