Sc 495 error code
Sc 495 error will showing my copier
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
bowdo
  • 78 Answers
SOURCE: LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Posted on Feb 12, 2008
munybuny
  • 14 Answers
SOURCE: Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Posted on May 20, 2008
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
NALDZ
  • 38 Answers
SOURCE: Functional Problem with RICOH Copier Error No-SC:541
YOU NEED TO RESET THAT CODE
Posted on Oct 22, 2008
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press 1 , 0 , 7
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Sc 495
SC495 is generally a problem with the toner recycling system in a Lanier copier. Without knowing the specific model, I can't give you any more information. What model copier do you have?
Oct 06, 2010 | Lanier Office Equipment & Supplies
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
k24674
jasbo
jasbo
