Question about Zanussi ZWF1430W Front Load Washer
My washing machine has run a 40o wash with cold water - have tried again and the front feels cold???
  • Zanussi Master
  • 3,463 Answers
AT 40oC, I would not expect the door glass to feel hot, but to check if the heater is working o/k, run it on a 90oC wash programme.
The door glass should feel quite hot.
If it it still feels cold after say 30 mins or so, then I would suspect that the heater is not working.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
Cold water not going into my machine sw80usp
Make sure both water valves are on at the supply. Set the machine to warm wash/warm rinse and start it, feel the water coming in, then turn off the water valves at the supply.to take the water pressure off the hoses, then turn off the machine.Then swap the H and C water hoses at the back of the unit, then turn it on to wash again. If you now get cold but no hot, the cold water valve solenoid is bad, replace it.
Feb 16, 2015 | Washing Machines
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidare galllery series washer when i wash sometimes it wont spin and it says E10
Hello, The E10 error code indicates there is no cold water coming into the machine, either this is because the inlet valve is bad or there is a kink in the cold water line or a blockage in the filter screen where the cold hose hooks up to the machine or one of the kids turned the cold water off at the back of the machine :) Either way you should check everything I have listed, If you can't find a blockage replace the inlet valve. If you have any questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 09, 2009 | Frigidaire GLTF2940ES Front Load Washer
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
ZANUSSI ZWD162701 washing always comes out cold - WHY?
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Thanks.
Jan 07, 2009 | Zanussi ZWD1270 Front Load Washer / Dryer
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
No cold water on cold settings
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
cbinny1
Jan 04, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Zanussi ZWF1430W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
