Question about GE JKP15 Electric Single Oven
Reset controller GE JPK15
How can you reset the control panel
3 Suggested Answers
  • 1891 Answers
SOURCE: broiler element does not heat on ge jkp15bow2bb
ck the element and witing to control / then go to the control . elements are very common .. mm
Posted on Jul 15, 2010
MNfisherman
  • 11896 Answers
SOURCE: GE XL44 JGB26 Gas Oven.. Control panel display
partselect,com or repairclinic,com
I recommend partselect.com
Posted on Dec 31, 2010
None of the control panel button work on my GE profile oven is there anyway to reset it
No you will need to replace the entire control panel to correct this, it is all one piece, buttons and board.
Nov 04, 2016 | GE Ovens
GE oven controls lock after opening door and steam from cooked food comes out
you may find there is some insulating material missing internally as I would imagine steam affecting the front of the control panel
Nov 14, 2013 | GE JTP70 Electric Single Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE Oven JKP56...after Self Clean bottom element in upper oven stays hot. Breaker off, let cool, breaker on...bottom element gets warm (all controls off). the breaker is off for now. Please help.
    Hello, Thank You for using FixYa. I will be helping you today.Leave the power off remove the screws from under the panel and lift up to open the control panel. There are reset-able fuses in there check them by pressing the center red button if they are ok check the screen in front of the fan make sure its not blocked up it will cause this problem too.If all that is ok then the relay on the control fused closed and you would have to replace the control board with the relays on it.
    Thank You and please rate my answer if it was helpful..
    Jun 11, 2011 | GE Profile JKP56 Electric Double Oven
    GE stove JSP40BB has digital readout all lit up. turning off power did not reset it.
    Unplug the range.
    Open the control panel to access the clock control.
    Remove the wires from the control for 30 seconds.
    Replace the wires on the control and plug the range back in.
    If this does not clear the control you will have to replace the control.
    Jul 24, 2010 | GE Ovens
    Broiler element does not heat on ge jkp15bow2bb
    Jul 14, 2010 | GE JKP15 Electric Single Oven
    Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
    F7 stuck keypad
    Stuck keypad may mean relay is turned on.
    Determine if problem is with the Key Panel or Control by:
    1. Pushing CLEAR/OFF pad.
    2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
    If code recurs, problem is in the control. Replace control.
    If code does not recur, problem is with the Key Panel.
    Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
    I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
    F7 stuck keypad
    Jul 30, 2009 | GE JTP45 Electric Double Oven
    Changed the lite bulb on ge double ge eletric oven and it blew
    There is no reset switch on the oven you blew the breaker in the control panel. you will have to find it and flip it.
    Dec 21, 2008 | GE Profile JTP56 Electric Double Oven
    GE JKP15 Electric Single Oven Logo
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
