Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon Fax G3 How do you set the date and time?
  • shirley942 Jan 23, 2009
    How I can set up the fax so I can get the confirmations
Lifted up the side panels and found the correct button to set the date and time.
Thanks!
Posted on Jan 06, 2009
Canon 2060 Super G3 fax - how do I change the date and time?
lift up speed dial cover, choose data ragistration, and under machine sett. find date and time.
Jun 24, 2010 | Canon LaserClass 2060 Fax
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
When I send a fax the date is wrong. how do I fix that?
set date and time in ur machine correctly. it is in user settings
Jul 06, 2009 | Canon Office Equipment & Supplies
How to set the date and time
Below are instructions for changing the Date and Time for your machine. At the end, you will find a link for the owners manual for the 2060. Best of luck.
Greg
Entering the Date and Time
Follow these steps to enter the date and time.
1. Open One-Touch Speed Dial panel.
2. Press Data Registration.
3. Press Set twice.
4. Press Set again, then use the numeric buttons to type in the correct
date and time.
Use the MM/DD/YY format for the date and use the 24-hour
clock for the time, so 2:30 p.m. would be 14:30, for example.
5. Press Set to save the date and time.
6. Press Stop to return to standby mode.
http://aaabusinesssystems.com/pdf/_2060_Users_Guide.pdf
May 29, 2009 | Canon LaserClass 2060 Fax
Changing Date/Time on Canon Super G3
Menu..... Timer setting, under Settings menu.
Jan 29, 2009 | Office Equipment & Supplies
I Have a Cannon, Laser Class 710, Super G3 Fax Machine and need to know the procedures to reset the time and date. Can't find my manual.
lift up the 3 speed dial panels
use Data registration key
select date/time settings
use the 4 direction arrows to navigate thru menus
and after changing info use set key to lock in setting
let me know if ya need more help
these are great faxes
May 23, 2008 | Canon Office Equipment & Supplies
HELP
We also have losted our manual and need to reset everything but can't rember how to do it.. Can someone please help me out on this problem. Very much appreciated!!
Jan 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Menu locked on a super g3 3170 laser fax machine
Need to change the time and date and can't seem to get the menu to work properly
Jan 22, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
278 people viewed this question
old marine
old marine
