Question about Samsung AW0693L Air Conditioner
Saftey cord I have a saftey breaker in the cord this trips after 2-3 min of use on all modes of operation can you help
  • 237 Answers
For 2-3 three minutes of running does it run normally? No abnormal noise the air out of unit is cool, if you have clamp tester you can check if the current reading of unit is normal, if everything is normal then there is something wrong with your circuit breaker, it needs replacement or your circuit breaker is under rated.
Posted on Dec 31, 2007
Maytag neptune front loading washer MAH8700AWM. FRONT LOADER, JUST OVER 2 YEARS OLD. STOPPED WITH 11 MINS LEFT IN THE COLOR CYCLE WITH ERROR CODE "EE" EXCEPT THE FIRST E IS MISSING THE TOP...
Hello MrBig57,
Try unplugging the washing machine from the mains for about 15 minutes, turn off the circuit breaker to that socket. After 15 minutes, turn on the breaker, plug the machine back and see if it responds normally.
If that does not work, it could indicate a problem with the control panel or some other component that will require dismantling.
I recommend you get a professional to to do the job.
If you wish you can contact Maytag HERE.
Or call them using these numbers:
(866) 616-2601 U.S.
(800) 688-2002 Canada
Hope that helps!
Thank you for using FIXYA!
Cheers!
IrishDruid
May 11, 2008 | Washing Machines
My Neptune dryer trips the breaker after 2 to 3 min on lowest heat setting. Used to trip it only at highest heat after 15 min. Got worse over 10 years. Can anyone help? Thanks Dave
If you are tripping the breaker for any reason then you have a short somewhere within your machine and you need to call a tech to isolate the problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Maytag Dryers
BREAKER TRIP AFTER 8 MINS .WORKED ONLY ON PERMANENT PRESS FOR A YR NORMAL ..WOULD TRIP BREAKER ON LOW AND HEAVY SETTING AFTER 5 MINS CYCLE.
This problem might be in your house electrical system rather than the dryer but it will take some troubleshooting to figure it out.
1. First make sure that you are connected to a 30 amp circuit breaker. If not then that is the problem!
2. Use a clamp on amp meter to see what the dryer is drawing from your electrical panel before it trips. If it is below the rating of the 30 amp circuit breaker when it trips, then your circuit breaker is defective.
3. If the dryer is drawing more than 30 amps it is in your machine and you will need to troubshoot that. Since you stated the times - is it always the same and does not vary? Then you have to figure out what you dryer is doing at the 8 minute mark and each machine is a little different. Soem machines go into a tumble air only mode for the first few minutes before kicking on the heating elecment. If yours is that was then it is the heating element, thermostat or something to do with the heating circuit.
Jun 20, 2011 | Dryers
My Campbell Hausfeld 30 gal 6.5 hp oilless compressor, WL611201 trips the breaker when I switch it on auto. But will not trip the breaker if I use the breaker as an on off swithch. However, it somtimes...
not likely as your pressure switch is pneumatic, What else operates on that same breaker, perhaps replace the breaker as they sometimes get "tired"
hope this helps
Let me know
Dec 18, 2010 | Campbell Hausfeld Air Tools & Compressors
Runs for a few min then trips one of the 2 breakers. to make sure it was not the breakers,i switched the hot leads in the plug, and just as i thought the other breaker then tripped. so i assume the problem...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would say that the motor is going bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 01, 2010 | Kenmore 62602 Electric Dryer
Last night the frigidare AC with breaker in line
if the breaker reset and the display lights are lit its not the cord sorry to say could be compressor or fan motors.
May 06, 2010 | Maytag M7Y12F2A Air Conditioner
Power loss during use. No lights on console. Other appliances on line ok. Circuit breaker not tripped. Model W10073320
your dishwasher is possible to have an imperfect wire conection on the cord or inside. unplug the washer and check the wires or much beter: call a repairman for your saftey!
Feb 23, 2010 | Dishwashers
Circut Breaker Trips
If the fault were with the product, the breaker would trip right away. You have either a poor electrical connection (power supply) or a weak or undersized circuit breaker. Free standing ranges usually use a 50 amp double pole breaker. Check electrical connections at breaker, range recepticle, and power cord to range to make sure all are tight. (obviously, have breaker off when making these checks)
Nov 23, 2009 | Refrigerators
My krups 9000 keeps on setting off the saftey switch at the main powerboard off my home
you mean house breaker i guest you tried the machine somewhere else and if still blowing breaker check the power cord open it maybe with vibration power wire are toughing themself inside machine cheers
Jan 26, 2008 | DeLonghi EC140 Espresso Machine
Samsung AW0693L Air Conditioner Logo
69 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
