Question about GE 24" Built-in Single Electric Wall Oven - Black
Oven will not work after loss of power GE JKP15BW
Lost power and now oven won't come on after it was restored.
4 Suggested Answers
  • 18 Answers
SOURCE: Can't make my oven work after a power loss - GE Profile Advantium
check voltage to oven. if thats ok your control board may be shot.
Posted on Feb 04, 2007
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
nainamainaka
  • 380 Answers
SOURCE: ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Posted on Nov 22, 2011
    Oven won't heat
    major electrical problem. call a repair man asap!
    May 19, 2013 | GE Profile JT912 Electric Single Oven
    GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
    if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
    Nov 24, 2012 | GE JGRS14 Gas Single Oven
    Ge oven jtp18 elements won't heat
    The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
    http://www.on-timeappliance.com/ovenrepair.html
    Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
    Ge profile oven lock button won't go off
    or
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Oven won't heat up past 200 degrees
    The temperature sensor needs to be checked.It must not working properly. thanks.
    Oct 11, 2011 | GE JTP45 Electric Double Oven
    We have a GE XL 44. The oven won't heat up at
    sounds like a bad control panel , I bet it is a touch button type if it is get all the info off unit and order control panel here http://www.appliancepartspros.com/
    Jul 27, 2011 | GE Ovens
    GE jvm140k prchase 1993. Oven timer works and displays time and progaming but oven won't start up. It has been working off and on but now won't work at all.
    The model you gave was for a microwave oven. In the backside of the microwave is a air cooling window. If it gets clogged with junk the mag will overheat and the limit on the side of it will shut down the oven. Simply cleaning this area so that air can circulate better can cure the problem. I suspect it finally got so bad that the cavity thermal limit has blown now and you have nothing at all.
    I have a service manual and more HERE
    May 27, 2011 | Ovens
    Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
    Feb 01, 2007 | GE Profile Advantium SCB2001KSS Stainless...
    GE 24" Built-in Single Electric Wall Oven - Black Logo
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
