Question about Coffee Makers & Espresso Machines
What does a flow restrictor sprayhead do for a bunn grx-B
How do i install this sprayhead
  • 131 Answers
SOURCE: Using fine grind coffee in
Phone Bunn Directly, and ask for their warranty department. In canada, you can call 1-800-263-2256. In other countries, go to www.bunn.com for the phone number closest to you.
Posted on Feb 11, 2009
FixinFax
  • 3085 Answers
SOURCE: MY Bunn coffee maker GRX leaks .
Complain loudly to Bunn, they fixed mine for free.
Posted on Dec 09, 2009
  • 189 Answers
SOURCE: Bunn GRX-B leaking from bottom
If you will locate the date code on the bottom of the brewer and contact Customer Service, the machine can either be replaced or repaired at not cost or if over 3 years old, at a reduced price.
Posted on May 19, 2010
  • 189 Answers
SOURCE: Unable to remove our sprayhead from our Bunn NHB Coffeemaker
You might try putting a butter knife underneath the sprayhead to remove it. If this doesn't work, then please contact customer service and request a tool that can be provided to remove the sprayhead.
  • 189 Answers
SOURCE: Need wiring diagram for Bunn BX or GRX coffee
I do apologize but these diagrams are not available. What is the problem with the machine? If you will get the model and code date from the bottom of the brewer and contact customer service, we can help resolve your issue. The machine carries a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, then it will be replaced at a reduced price.
Why does my Bunn coffeemaker spill over the filters when I use Bunn Filters.
I purchased a special flow restrictor sprayhead from BunnAtHome.com because I use decaf coffee. Also if you use a finer grind then you need this to slow the water so it doesn't overflow.
Jul 07, 2014 | Bunn 10 Cup Home Coffee Brewer
My Bunn velocity brew machine is always overflowing. What can I do? Thanks John.
This is several things it can be to cause the overflowing problem. Most the time is will be some of these.
  • Use BUNN paper filters.
  • Check to make sure the sprayhead is in place.
  • If you use decaffeinated, fine grind coffee or have soft water, you need a flow restrictor sprayhead.
Here is also a link with other trouble shooting areas to check and Phone number if needed to order parts directly from bunn.
http://www.bunnathome.com/troubleshooting/velocity-brew
I hope this helps you, if not please contact me back and I will help you until you are satisfied. Thanks Mc1bean your Coffee Expert.
Nov 02, 2011 | Refrigerators
The water dont seem to brew all the coffee in the filter....parts of the coffee is still dry....i have cleaned the pot and spray head and empty the tank and refilled with water...my bunn is only 3 months...
It sounds like you are either missing a sprayhead or need the flow restrictor sprayhead. If you will call customer service at 800-352-2866 we will be happy to resolve this issue for you.
Sep 17, 2010 | Bunn 10 Cup Home Coffee Brewer
I have a bunn auto brew w/2 warmers.flow control/filter is installed and the basket overflows...
Either the coffee grind is too fine, too much coffee or incorrect sprayhead. Count the amount of holes on the sprayhead.
Aug 29, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
If i try to make more than 6 or 8 cups in my 10 cup bunn coffemaker. The coffee grounds overflow . This is a new coffee maker and we find a mess almost every time we make a pot. We have alwats used bunn...
This can occur with the use of finer ground coffee or use of soft water, filtered water, or bottled water. If you will call 800-352-2866 with the model and date code, we can send you a flow restrictor sprayhead which will alleviate this problem.
Jun 20, 2010 | Bunn 10 Cup Home Coffee Brewer
Coffee grounds overflow
Tressia,
An overflow can occur when using certain brands of coffee that are finer ground or using a water softener, bottled water, reverse osmosis, or filtered water. If you will call Bunn Customer Service, you can get a flow restrictor sprayhead which will eliminate this issue.
May 08, 2010 | Bunn NHB Coffee Maker
Grounds in coffee. am using bunn coffee filters and still have a mess in my cup and in filter
Are you using a finer ground coffee? Or do you have a water softener, use filtered water or bottled water? If so, please call customer service to get a flow restrictor sprayhead which will eliminate this issue.
Dec 07, 2009 | Bunn NHB Coffee Maker
Coffee grounds leaking out of the basket
When you are grinding your own beans or use certain types of coffee, you need to use a flow restrictor sprayhead. If you will contact customer service, a flow restrictor sprayhead can be sent out to you at no charge and this will eliminate the problem you are having.
Mar 03, 2009 | Bunn Thermal Carafe Coffee Brewer
My7 GRX Bunn coffeemake doesn't brew in 3 min-more like 12 and I don't believe the water spray is working although I am not sure.
It is becomming clogged. Start with the sprayhead. Check all of the holes, be sure water is running from all 5 holes. If the sprayhead is clear, check the water tube. Use your delimer spring. Don't shove it in. Twist in through as if it were a drill bit. If it starts to become resistant don't keep twisting, you may not be able to get it out because of a lime scale blockage. Not knowing where you live or the grain of the water you use, I can't say for sure. But if the spring goes in and you are left with about two inches of spring comming out of the sprayhead you may have cleaned what was blocking the water out of the way. Now run a pot of water without the sprayhead or brewbasket. Just put your pot underneath and pour water in with the Bunn pitcher. Is the water comming out in a good stream now. If so put the sprayhead back on. If the problem presist check to be sure that the nut that holds the spraytube in place. It is the nut right in front of the sprayhead. If it is there then you may want to get a new sprayhead. Rick in Indy
Jul 30, 2008 | Bunn GR10 Coffee Maker
Coffee Makers & Espresso Machines Logo
95 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
